January 2026
4 5 6 7 8 9 10
11 12 13 14 15 16 17
18 19 20 21 22 23 24
25 26 27 28 29 30 31
Like Tree1Likes
Old 08-28-2008, 06:59 PM
Double Venom's Avatar
Done!
DV
Old 08-29-2008, 04:40 AM
capteddie's Avatar
Cobra Make, Engine: CRII 351W/408 Stroker
Send a message via AIM to capteddie
Originally Posted by Double Venom View Post
Hopefully tomorrow after noon we'll fire it up via "hot wire" then the remote/button starter will be finalized.
HEY!!!! I read right past this one....
You better call me, so I can hear it
I'll PM you cell # in case you can't find it.
Cheers!!!
"the other ed"
Old 08-29-2008, 10:12 AM
Default Re-modified dash and dash wiring
Cpteddie,
Just so you can see;
Switch #1- Windshield wipers
Switch #2- Headlights
Switch #3 Red - Main power switch
Switch #4 Fan over ride
Right side of column:
#1 Holley Choke-Manual
#2 Ignition switch
Top large gauge - Speedometer
Bottom Large gauge -Tach
Center Gauges:
Top left - Oil Pressure
Top Center - Oil Temp
Top Right - Water Temp.
Bottom Left -Fuel
Bottom Right - Volts
As requested..
DV
ps- your tach & speedo have been switched- gotcha!
Old 08-29-2008, 11:38 AM
capteddie's Avatar
Looking good DV...
Sent you a PM about the drive shaft and the tubing.
Let me know if there's anything else you need. Have a good weekend and don't work to much. People are starting to comment on our work habits
"the other ed"
Old 08-29-2008, 05:52 AM
James Stern's Avatar
Cobra Make, Engine: Classic Roadster, 302, roller cam, Holley 650
Don't you guys ever sleep? Captain Eddie you really should rest the back & DV you just need to rest! It's getting to the exciting part in the build but I'd rather see the both of you in good health to enjoy the finish.
The one line never heard in heaven; "Gee, I wish I had spent more time in the office."
Old 08-29-2008, 06:20 AM
Buddy,
My sleep patttern is as normal as ever, it sucks but it is normal. I did make a mistake though, I lost a day, thought this was Saturday- DUH! Actually aiming for a late afternoon startup on Saturday. Just my normal work day,
DV
Old 08-29-2008, 06:43 AM
Buddy,
Just Heim and Bracket:
Full shaft with new heim:
DV
Old 09-03-2008, 08:26 PM
John,
ME turn away a Cobra!? Cpteddie must still be cracking up.over that one. In all honesty there isn't enough Cobras to build! The only thing I do different now since I am retired is I have (per my wife) cut down from 7 to 12 to one or two plus maybe a street rod to keep things interesting.
What filler cap are you referring to? I've been trying for a couple of months now to get caught up enough to remold the Lemans cap filler, is that the one you need?
If you have time come on up Sat. Cpteddie will be here and if I have (and should have) his drive shaft here in time, I want to fire it up for him since he will be here too.
In all seriousness, I could start your painting in November but I will need the frame for a couple of days as I Install the body, match all the parts and especially the doors to the frame then pull it all apart again. Frame can then go into storage or go back home until the body is painted.
Cpteddie, I think those three points are going to be right on time!
John, the oil cooler is a Finishline model, not any special brackets. I cut and welded in a piece of straight steel 3"x12 +/-, welded it in the frontal area, then when I mount the body build the aluminum shield around the inlet. I'll re-install giving the cooler a solid place to be bolted in. You don't even need to drill and tap, simple chrome/stainless 1/4x20 bolts work great.
DV
Old 09-03-2008, 08:51 PM
capteddie's Avatar
LOL!!!
I didn't think you'd be back on tonight.... And yes I was laughing my A$$ off.
John. Please don't take this the wrong way. I think I kinda kicked DV out of his chair and back into the cobra building business. Not sure if he really knew what I was getting him into, but I do know he's had a good time so far and I think there are a lot of people who have benefited from him sharing his knowledge here. Hell we have over 14K views on this thread.
He's right. If you can make the trip up on Saturday, I don't think you'd be disappointed. He's done an unbelievable job on my car, adding things I would never of thought of and also steering me away from some bad decisions (and believe me, I've made some).
I'm leaving from work on Friday and will get close to his place and find a room. I'll be at DVs early on Saturday and leave around 3 or 4 in the afternoon. Seeing my car might give you some insight into whats to come.
DV.... Tell the wife its not my fault
See you Saturday!!!!!
"the other ed"
Old 09-03-2008, 09:01 PM
Yes, the Lemans cap, was conserned that the cap filler was now longer available, sounds like you have that under control!!!
Can not make it this weekend, have work to do at the lake house in NE Indiana before closing for the winter.
Will call and talk tomorrow. Will drag the Rolling Chassis out and send pictures for you to see, then you can let me know what needs to be completed before hauling to you. This will allow you to let me know how much this might cost!!!!
Was going to try to complete all Body and Paint myself, used to own a BS, but I have been telling myself that for about 8 Years, would like drive it a little while I can still remember that I have a Cobra..............
Thanks for the help!!!
Steve Townsend
Steven L. Townsend
Old 09-03-2008, 09:15 PM
capteddie's Avatar
Steve = johnbcom Ok....
Steve,
If your talking about the flip cap itself, check this out.
http://www.finishlineaccessories.com...roducts_id=383
If your talking about the fiberglass fuel well that gets mounted into the rear fender? Then talk to DV. I think he made a mold of mine, so he can replicate them as needed.
"the other ed"
Old 09-04-2008, 09:18 AM
Yes, I am talking about the Fiberglass, and knew of the Flip Cap @ finishline. Thanks for the reply!!
Steve
Steven L. Townsend
Old 09-04-2008, 09:53 AM
capteddie's Avatar
If you don't here back from DV about the fiberglass spillage well before Saturday, I'll mention it to him when I see him.
"the other ed"
Old 09-04-2008, 11:02 AM
Uh, I know about it, been a little busy building some guys Cobra I have the Buck made, just need the time to clean it up and start "Splashing" copies.
DV
Old 09-04-2008, 11:11 AM
John, (?)
If this is any help, it is a picture looking straight down on cpteddies oil cooler. I think what brackets you may be seeing in the original picture are part of the brackets I made to hold his radiator in.
DV
Old 09-04-2008, 01:31 PM
Cpteddie some more for you!
Roll bars came in too-now if we can get the Chinese to let go of some steel! Winter Project: Although these are #10's they fit loose, to really make em look good have a machine shop take off 3/32's on each half and re-assemble, then they will be perfect. Also if they have a #10/#6 combo that would be perfect!
Old 09-05-2008, 05:12 AM
capteddie's Avatar
Ok DV...
Heading for MI right after work today. Will get close to your place (probably Muskegon) and get some dinner, along with a room for the night. I should be at the shop around 9-9:30 Saturday morning.
Looking forward to seeing our baby!!!!
"the other ed"
Old 09-05-2008, 09:29 AM
cpteddie,
In all honesty, the Mrs. thinks it's silly to drive all the way to Muskegon and get so close and spend a night in a motel. Another 40 minutes and you can be here and spend the night, you certainly aint gonna be the first Cobra guy to spend a night with us!
Company may not be great but Chrissy is friendly! Assuming you will eat supper on the road, what do you want for breakfast?
Of course if you want your privacy I understand that too.
DV
Old 09-05-2008, 10:05 AM
capteddie's Avatar
Well DV....
Thanks for the offer. You and I have since spoke on the phone and you know what's going on
Keep me posted on our baby and let me know if you need anything. Back surgery is scheduled for the 19th of September, so you probably will not be seeing me in person until the middle of October
"the other ed"
Old 09-06-2008, 03:21 PM
capteddie's Avatar
OK DV...
We're looking good!!!!
Going to get a good nights sleep and....
See you tomorrow!!!!
"the other ed"
Display Modes
