January 2026
4 5 6 7 8 9 10
11 12 13 14 15 16 17
18 19 20 21 22 23 24
25 26 27 28 29 30 31
Old 08-25-2008, 04:12 AM
Default Talk to the dirt track guys
Jac Speedway is a good place. Get a straight bar, min 3/4"- max 1" and the 2 mounts. The ends are splined so you have total adjustment for the bar. You will want the ends to clear the frame by about 2 inches. You will need to jack the car up on jack stands, (level) and turn the wheel max right and left to see where you mount the bar and clearing the wheels. This will give you the length on the bar. They sell straight or bent end arms with solid ends. They also sell link kits to the lower controll arms. You will need a kit with weldnuts to install on the frame. Look at your car or truck to see how to setup the bar. Rick L. The links should be straight up and down with the bar mounted complete.
Display Modes
