02-04-2010, 01:42 PM
Mechanical Throttle Linkage for Factory Five
I am making some changes to a Factory Five cobra. There is a cable linkage setup right now on the car but it has a sticking point. The cable comes out of the front foot box up high and makes a sharp right turn and then bends again to make the turn come into the rear of the carburetor. Does anyone make a better setup or mechanical one like ERA but will work with the Factory Five?
Thanks for the help!
02-04-2010, 02:01 PM
You will have to custom make it yourself. You can get all the parts from McMaster-Carr
02-04-2010, 02:10 PM
I make all the parts for them per original if you wanted to try some parts to see if it will work for your set up.
02-04-2010, 02:29 PM
Try turning the carb around and having a front entry to the cable. Some have done it to eliminate the S bend.
02-04-2010, 03:38 PM
Cobra Make, Engine: Lonestar LS427, 408w, 48IDA Webers, TKO 600, 9" Currie 4-link 4.11 rear
Ernie,
I recently did a modification that allowed the cable to pull the throttle from the front of the carb, not the back. Great modification, looks great, works 100% better. I did this for the same reason you are looking at the mechnical.
If I had to do it all over again, I would go mechnical, but it would be really tough in my engine bay. This front cable pull is the way to go, and was really easy to do.
02-04-2010, 04:33 PM
Cobra Make, Engine: Hurricane Motorsports, 427w
Mechanical linkage is on my to-do list. Here's another source for parts if you want to fab your own.
http://www.midwestcontrol.com/
Hurricane Motorsports #1053; 427w
02-04-2010, 04:49 PM
Do you also make original style brake and clutch pedal shafts?
05-20-2013, 08:38 PM
I am in the process of building a big block FFR and I am looking for a larger gas tank, anyone know where one can be obtained? Stock Mustang tank doesn't give much cruising range.
05-20-2013, 08:54 PM
Fuel Safe makes a fuel cell that holds 20+ gallons and bolts right in
05-21-2013, 05:33 AM
Do you want a tank or a cell?
05-21-2013, 05:44 AM
ma
Cobra Make, Engine: factory five mkIII roadster 445 fe quick fuel 750 q series,irs
I run the stock cable on my ffr with the cable coming out of the foot box making one u bend and it is from the front, I used a throttle cable bracket from summit and had to fab a mount to lock the cable. here are a few pics.
factory five mk III roadster, 445 fe stroker
05-21-2013, 10:52 AM
Sorry Bill I haven't been getting notifications for a while as you can see
Yes I do.
