| S |
1 |
| 3 |
5 |
8 |
| 10 |
12 |
15 |
| 17 |
19 |
22 |
| 24 |
26 |
29 |
30 |
| 31 |
440Likes
07-26-2021, 08:08 AM
CA
Cobra Make, Engine: Factory Five
Bill, I'm not sure how you'd do it now, but I installed the wires before I bonded the inner and outer skins. There really isn't much space between the skins, at least in a direct line. Had to follow the rib that runs around the outer edge. I hope someone else has an actual method that will work for you.
07-26-2021, 10:10 AM
CA
Cobra Make, Engine: FFR chassis and suspension, Mr. Bruce 289 FIA body
Maybe I’ll just tape the wires to the inside of the trunk lid
07-26-2021, 10:57 AM
CA
I was thinking that you might be able to use pex tubing in the 3/8" size. bend it to match the rib in the trunk, and maybe use silicone to bond it in place. Then the wire would be in a "conduit", and at least protected somewhat. If you had some of the body color paint you could even paint it to make it blend in better. That's my best idea, now I'm going to have to go take a nap to rest up!
07-26-2021, 11:01 AM
NH
Here is how it was done in the 60's.
07-26-2021, 12:24 PM
NC
That's exactly how I did mine.
Thanks Jeff, I couldn't take a picture
John O
jjo42
07-26-2021, 11:07 AM
CA
THAT’S IT!
Thanks!
07-26-2021, 02:17 PM
CA
1985ccx
The email was an old one that doesn’t exist I updated it. It’s wkdobbins@hotmail.com
Thanks
07-26-2021, 05:07 PM
Tx
Cobra Make, Engine: Hurricane, 351W bored and stroked to 408
Bill, if you don't want the wires visible, on my Hurricane the the inner skin of the truck had a hollow area between the inner skin and the outer surface of the trunk and and I drilled a hole in the hollow part of the inner skin near the drivers side trunk hinge and a hole at the back of the license plate light and fished a wire down to the license plate light and pulled the light wires through so the wires were hidden from view except up by the truck hinge and at the license plate light. Hope that makes sense.
07-26-2021, 05:10 PM
CA
I don’t have that option S_reynolds.
07-26-2021, 08:31 PM
CA
Made some good progress tonight after it cooled off. Installed the front nose side aluminum pieces and the oil cooler mounting plate, the oil cooler, and associated braided lines
Bill
07-27-2021, 05:26 PM
CA
Some good progress today with the cooler weather. Installed the hand-formed aluminum oil cooler scoop and the functional brake cooling ducts
Going to take a break tomorrow
Bill B
07-27-2021, 06:02 PM
NY
Bill,
Looking great! You deserve a well needed rest. When you get a chance, I would be interested in seeing how the brake cooling ducts are mounted at the brakes.
Take care.
Jim
07-27-2021, 11:54 PM
Hey, Bill D, you need to change your name!
It should be BuilD!
Awesome work!
Paul
Unique Motorcars 289 USRRC
1964 289 5-bolt block
Toploader and 3.31 rear
07-28-2021, 01:56 PM
CA
Jim,
In the front I purchased a set of brake duct flanges that mount to the Mustang spindles. In the back I fabricated my own mounts
Bill D
07-28-2021, 06:33 PM
SA
I like the aluminium alloy scoop for the oil cooler.
Very nicely done, Bill.
If mine wasn't already done (and painted), I think I'd copy your design
Glen
07-28-2021, 08:32 PM
CA
Lucas PL700 headlamps
07-30-2021, 07:48 AM
CA
Deleted comment
07-30-2021, 09:07 AM
NH
My wires are different color, sorry
07-30-2021, 11:14 AM
WI
Bill B
Awesome! A true work of automotive art.
Tropical Buzz
07-30-2021, 02:01 PM
CA
Taillights and bungee cord mounts. Progress! I’m on a roll now!
| Thread Tools |
| Display Modes |
Rate This Thread |
Hybrid Mode
