Like Tree440Likes
LinkBack Thread Tools Rating: Thread Rating: 4 votes, 4.00 average. Display Modes
  #341 (permalink)
Old 07-24-2021, 06:30 AM
Buzz's Avatar
Thumbs up
Looks stunning already! I really look forward to seeing pics of the finished car.
jolsen42 likes this.
Tropical Buzz
  #342 (permalink)
Old 07-24-2021, 09:29 AM
Bill D's Avatar
Is this the stuff to use to attach the nose and trunk COBRA emblems to the body?
  #343 (permalink)
Old 07-24-2021, 01:34 PM
Bill D's Avatar
Tried to install the transmission cover but none of the rivet holes line up. What would cause this? They lined up and we’re held with cleckos before going to paint last year. Hate to oblong the holes and risk ruining the cover and/or the rivets not holding securely
1985 CCX likes this.
  #344 (permalink)
Old 07-24-2021, 05:56 PM
Bill D's Avatar
I was able to install the transmission cover with a combination of muscle and Re drilling the holes.
On another note, I installed the door panels, fuel filler, fuel splash guard, license plate holder, and side emblems. But it’s 98 deg in the garage and just too hot to continue
Buzz, NROTOXIN, rads42 and 1 others like this.
  #345 (permalink)
Old 07-24-2021, 06:38 PM
jmimac351's Avatar
Cobra Make, Engine: Building 289 Lemans / FFR mkIV chassis w/ Bruce Chervenak
Incredible job, Bill! You should be proud.
Pics---> www.jmimac351.smugmug.com
Chief Instructor: www.ChinTrackDays.com
  #346 (permalink)
Old 07-25-2021, 05:15 PM
Bill D's Avatar
How are people running the wires to the license plate light!
  #347 (permalink)
Old 07-26-2021, 06:03 AM
Sawdust's Avatar
Looks fantastic Bill. Kudo’s to you and your workmanship ��
  #348 (permalink)
Old 07-26-2021, 08:08 AM
EZ$ EZ$ is offline
Cobra Make, Engine: Factory Five
Bill, I'm not sure how you'd do it now, but I installed the wires before I bonded the inner and outer skins. There really isn't much space between the skins, at least in a direct line. Had to follow the rib that runs around the outer edge. I hope someone else has an actual method that will work for you.
Bill D likes this.
  #349 (permalink)
Old 07-26-2021, 10:10 AM
Bill D's Avatar
Maybe I’ll just tape the wires to the inside of the trunk lid
  #350 (permalink)
Old 07-26-2021, 10:57 AM
EZ$ EZ$ is offline
I was thinking that you might be able to use pex tubing in the 3/8" size. bend it to match the rib in the trunk, and maybe use silicone to bond it in place. Then the wire would be in a "conduit", and at least protected somewhat. If you had some of the body color paint you could even paint it to make it blend in better. That's my best idea, now I'm going to have to go take a nap to rest up!
  #351 (permalink)
Old 07-26-2021, 11:01 AM
1985 CCX's Avatar
Here is how it was done in the 60's.
jolsen42, Bill D and Mongoose930 like this.
  #352 (permalink)
Old 07-26-2021, 11:07 AM
Bill D's Avatar
THAT’S IT!
Thanks!
  #353 (permalink)
Old 07-26-2021, 12:24 PM
jolsen42's Avatar
That's exactly how I did mine.
Thanks Jeff, I couldn't take a picture
John O
1985 CCX and Bill D like this.
jjo42
  #354 (permalink)
Old 07-26-2021, 01:06 PM
1985 CCX's Avatar
Bill
I emailed you on another detail....
Bill D likes this.
  #355 (permalink)
Old 07-26-2021, 02:17 PM
Bill D's Avatar
1985ccx
The email was an old one that doesn’t exist I updated it. It’s wkdobbins@hotmail.com
  #356 (permalink)
Old 07-26-2021, 05:07 PM
Cobra Make, Engine: Hurricane, 351W bored and stroked to 408
Bill, if you don't want the wires visible, on my Hurricane the the inner skin of the truck had a hollow area between the inner skin and the outer surface of the trunk and and I drilled a hole in the hollow part of the inner skin near the drivers side trunk hinge and a hole at the back of the license plate light and fished a wire down to the license plate light and pulled the light wires through so the wires were hidden from view except up by the truck hinge and at the license plate light. Hope that makes sense.
  #357 (permalink)
Old 07-26-2021, 05:10 PM
Bill D's Avatar
I don’t have that option S_reynolds.
  #358 (permalink)
Old 07-26-2021, 08:31 PM
Bill D's Avatar
Made some good progress tonight after it cooled off. Installed the front nose side aluminum pieces and the oil cooler mounting plate, the oil cooler, and associated braided lines
Bill
jolsen42 and 1985 CCX like this.
  #359 (permalink)
Old 07-27-2021, 05:26 PM
Bill D's Avatar
Some good progress today with the cooler weather. Installed the hand-formed aluminum oil cooler scoop and the functional brake cooling ducts
Going to take a break tomorrow
Bill B
rads42 and 1985 CCX like this.
  #360 (permalink)
Old 07-27-2021, 06:02 PM
1795's Avatar
Bill,
Looking great! You deserve a well needed rest. When you get a chance, I would be interested in seeing how the brake cooling ducts are mounted at the brakes.
Take care.
