Like Tree8Likes
  • 7 Post By 1985 CCX
  • 1 Post By krausewich
Old 11-03-2016, 12:24 PM
1985 CCX's Avatar
Default Fantastic 289 Chassis - Very well done!
Mike K has spent countless hours designing and perfecting the 289 chassis using all the known plans along with first hand measurement.
WELL DONE MIKE!
From Mike;
Modeled it all in CAD based on the data I had, then rendered it up with some color. Every item used in it is exact to the brackets, tabs, and profiles that the chassis will be built with. So it is an accurate representation. I have the 427 as well, but I need to add in the rollbar, then re-render. The 427's are already available and out there! Will follow up with the 427 after I redo it in the next couple days.
My next frame will be a MK Frame...
FIA289, Igofastr, AndrewB and 4 others like this.
Old 11-03-2016, 12:52 PM
peterpjb's Avatar
its a FIA-chassis with cut-back doors ....
Old 11-03-2016, 03:23 PM
1795's Avatar
Looks fantastic! Sign me up!
Old 11-03-2016, 03:26 PM
1985 CCX's Avatar
Yup FIA.
Not too far off for std 289.
Old 11-03-2016, 03:46 PM
CompClassics's Avatar
Nice, other than the reverse radius tubes mounted at the door latch post area the frame can easily be adapted to a street Cobra configuration. There are other things like, the oil cooler mounting brackets, the roll bar mounting brackets and the 427 style radiator cooling fan brackets that can be removed as well. The 427 cooling fan bracket should just be a bolt on application anyway.
Old 11-03-2016, 10:14 PM
Send a message via AIM to krausewich
Exhaust hanger tabs, trans cooler and maybe driveshaft safety hoop bungs are about the only other items that would differ between the Roadster and FIA.
Thanks for the surprise kudos Jeff !
Mike.
CompClassics likes this.
-J. James
M. Krause
1.508.944.3368
Old 11-03-2016, 11:29 PM
LMH's Avatar
LMH LMH is offline
289 fan bracket is bolt on as well. Single fan on both 427 and 289.
It's beautiful work for sure!
Alba gu brąth
Old 11-04-2016, 05:58 AM
Cobra Make, Engine: Hawk 289 USRRC, 302 Ford
Which Bodies will fit? Very nice work!
Old 11-04-2016, 10:31 AM
Hi Monster..
It's an OE style frame, so any quality OE style body should fit nicely. This is designed for an aluminum skin, so there is a slight difference in birdcage fit/fab if going with a glass body as they are a bit thicker.
MK.
-J. James
M. Krause
1.508.944.3368
Old 11-04-2016, 01:01 PM
Igofastr's Avatar
Cobra Make, Engine: SPF GT40P-2265/393W, KMP318 (PROJECT!!!!!)/CSX478
So,
Is there a plan to sell chassis, complete cars, digital data, kits? Sorry, but I think I'm out of the loop on all of this.
Looks great, though!
Ron R
"Dishwasher? I thought that was for cleaning parts!?"
Old 11-04-2016, 09:25 PM
Hi Ron,
Thank you. Look for the debut of offerings come spring 2017!!
Mike.
-J. James
M. Krause
1.508.944.3368
Old 11-04-2016, 09:36 PM
Big brother was added to the mix earlier this year...
Keep an eye peeled for the naughty step-sister coming soon ; )
Club Cobra - krausewich's Album: Random goodies - Picture
-J. James
M. Krause
1.508.944.3368
Last edited by krausewich; 11-14-2017 at 10:18 PM.. Reason: Won't let me upload image!!??
