Like Tree390Likes
LinkBack Thread Tools Rating: Thread Rating: 4 votes, 3.00 average. Display Modes
  #201 (permalink)
Old 02-16-2020, 06:40 PM
xb-60's Avatar
....and here's the inner view....
  #202 (permalink)
Old 02-16-2020, 06:45 PM
xb-60's Avatar
Excuse the multiple posts. Can't work out how to attach more than one picture and have explanatory text in between. Is there a way?
Anyway, the rear panels for the inner guards ....I won't be fitting until after the exhaust is fitted. Those two panels (ie L+R) were obviously made to suit 427 guards/fenders as the profile is much different and will need considerable reshaping.
Glen
  #203 (permalink)
Old 02-16-2020, 07:00 PM
I think that looks just grand.
  #204 (permalink)
Old 02-16-2020, 07:07 PM
BJ's Snake's Avatar
Anyway, the rear panels for the inner gaurds ...I won't be fitting until after the exhaust is fitted. Thos two panels (ie L+R) were obviously made to suit 427 guards/fenders as the profile is much different and will need considerable reshaping.
Glen
Yes they do need reshaping and a pain to install with the body on.
289 FIA Cobras RULE!
  #205 (permalink)
Old 02-17-2020, 02:33 AM
xb-60's Avatar
You've already done this, BJ. Apart from those panels just mentioned, and the rear guard sheet metal trim strips, any other 427 panels will 'slow me down'?
Glen
  #206 (permalink)
Old 02-17-2020, 02:36 AM
xb-60's Avatar
Thanks Patrick. I left my finger prints there (#200), so no doubt as to who was responsible for the 'grandness'
Cheers!
Glen
Alfa02 likes this.
  #207 (permalink)
Old 02-17-2020, 02:41 AM
BJ's Snake's Avatar
Default Front extension panels
Glen
I was supplied the wrong front extension panels, wasn't evident till fitting the radiator.
It sat too low and the bolt holes didn't line up.
Pace recut and sent ones that worked after agreeing they were wrong.
Good luck with that now.
  #208 (permalink)
Old 02-17-2020, 08:53 PM
xb-60's Avatar
I avoided that one. PACE fitted the body to the chassis, so it had to be correct.
When are you in Adelaide next? Be good to catch up again.
Glen
  #209 (permalink)
Old 02-18-2020, 04:16 PM
BJ's Snake's Avatar
They fitted my body as well. The wrong panels weren't evident until radiator fitting.
Was your radiator fitted at Pace before delivery?
No Adelaide trips in the near future, you will probably be over here before I get over there.
  #210 (permalink)
Old 02-19-2020, 04:26 PM
xb-60's Avatar
Brett,
My radiator wasn’t fitted by PACE. You have me worried now! Fitting the radiator is next on my list.
Yesterday I went to start on the RH front inner guards and I wasted 2 hours looking for one of the aluminium alloy panels (the one the steering goes through). Couldn’t find it anywhere.
I’ve tried ringing PACE previously for things that were wrong or missing, with no luck, so I went to Paramount Brown’s (best ‘hardware’ in Adelaide) to buy some 1.2mm sheet aluminium to make a new panel. The guy serving me asked what I was using it for; told him about the Cobra, and he halved the price of the sheet! There are some nice people around still.
I’ll let you know how I go with the radiator fit.
Glen
1795 likes this.
  #211 (permalink)
Old 02-19-2020, 05:29 PM
1795's Avatar
Glen,
Hope that it works out well for you. Of course, you will find that part 5 minutes after you have installed the one that you spent countless hours on manufacturing...
  #212 (permalink)
Old 02-20-2020, 12:50 AM
xb-60's Avatar
Hi Jim,
Made the new panel....2 hours ago.
The missing panel? Well, it wasn't in the packaging with the related panels, so I think it just wasn't packed in the first place. No matter, slowed me down by a day, but...had a nice drive up through the hills to my favorite hardware, and an hour this morning to fab. a new one, and it's fitted now, so all good.
Will finish it tomorrow, and then must start on the radiator installation to see what surprises I might find there....from what BJ says, might take some ingenuity to get around it.
Hey, here it's around 25 degC (around 75degF), so life is good! Cool in the garage in the morning, and pleasantly warm in the pm.
Glen
  #213 (permalink)
Old 03-07-2020, 01:51 AM
xb-60's Avatar
Greetings Cobristi,
Time for an update.
I've been fitting the radiator. So, it's a job that should be an easy & quick bolt in job, right? First had to find the fan shroud....it was hiding in the trunk of my Alfa Eventually found it.
Fan to shroud was easy...
  #214 (permalink)
Old 03-07-2020, 01:53 AM
xb-60's Avatar
Can multiple pictures be posted with text in between? Haven't worked that out yet.
Radiator and fan and shroud assembled....
  #215 (permalink)
Old 03-07-2020, 01:58 AM
xb-60's Avatar
Next was to fit the radiator assembly to the car. The supplied side panels/brackets positioned the rad. assembly way too low. Had to drill new 18mm dia. holes in the brackets and also remove metal from the top as well as the bottom of the brackets. No sweat, except it all takes time. Make a mistake, and I'm in trouble.
Worked out OK, so here's the rad. assembly fitted to the car....
  #216 (permalink)
Old 03-07-2020, 02:02 AM
xb-60's Avatar
Next....need to fit a blanking panel to fill in the gap above the radiator to the underside of the body work to prevent air escaping rather than going through the rad.
Supplied panel is the small one. Can only assume that's for a 427, but my 289 bodywork is of course different, so had to make up the new panel (the larger one). Good fun...nice to have a bit of a challenge, but it all takes more time...
  #217 (permalink)
Old 03-07-2020, 02:03 AM
xb-60's Avatar
Here's the finished job....it all worked out OK, luckily...
Cheers!
Glen
cobrakiwi and Mongoose930 like this.
  #218 (permalink)
Old 03-07-2020, 04:57 AM
1795's Avatar
Such skill and craftsmanship! That's what building there cars requires, some ingenuity and perseverance. She's getting there Glen.
xb-60 likes this.
  #219 (permalink)
Old 03-07-2020, 06:31 AM
cobrakiwi's Avatar
Great stuff Mate, your getting closer to the finish line.
Very nice workmanship.
xb-60 likes this.
  #220 (permalink)
Old 03-23-2020, 10:11 PM
xb-60's Avatar
Finished the front inner guard alloy panels finally.
These of course will now be removed until after the exhausts are fitted.
All well out there? Stay safe!
Glen
