390Likes
02-02-2021, 11:42 AM
SA
Cobra Make, Engine: ICCARS,6.0LT L98 TR6060
Car is looking fantastic Glen, When do you envisage motor and gearbox will be in?
Can I ask what diameter master cylinders you are using for front and rear brakes and also clutch?
Richard
02-09-2021, 10:48 PM
SA
Richard
Sorry Richard.....haven't looked here for a while. I'll have a look for the m/cyl sizes
Glen
02-09-2021, 10:50 PM
SA
Mockup exhaust
Cheers!
Glen
02-23-2021, 06:12 PM
Hi Glen,
Do I get the sense that with this ...  ... in your post, that you are less than serious with this mock up? You have been a stickler for attention to detail and this in not in keeping with the rest of the build. Having a bit of fun are we?
- Tim
02-23-2021, 09:08 PM
SA
Originally Posted by tkb289
Hi Glen,
- Tim
Well picked Tim, but you took a while
Yes, it's the plastic tube from my junked Ryobi blower/vac.
Don't know how it got to be there...must have been my workshop manager....
02-24-2021, 02:05 PM
Thought you had a screamer pipe coming out with your side pipe, so a turbo we don't know about yet?
02-24-2021, 04:44 PM
Dang, and I kinda liked it.
02-24-2021, 10:01 PM
SA
It would look even better on your car, Patrick. If you pay the postage charge, I'll let you have it for nothing
02-25-2021, 12:57 AM
WA
Good job Glen, keeping us on our toes  Everything good with you? I've been busy moving to my "last" home "fingers crossed". Plus weather here is not Cobra driving yet. Been busy buying & selling new & old friends Cobras, this could turn into a business  Cheers Buddy, TommyRot.
03-10-2021, 10:22 PM
SA
Richard
Richard....I finally got around to it.
For master cylinder sizing (street use), I have 5/8" (16mm) for the front circuit and the rear m/cyl at 3/4" (19mm)
Clutch m/cyl size is 3/4"
Note: wheels are 15", discs sized accordingly
Cheers!
Glen
03-11-2021, 11:42 AM
SA
Thanks Glen,
That's reassuring as those are exactly the same as what I ended up with for my application. The Wilwood help line suggested I used 7/8" for rears and 3/4" for fronts but I found brake pedal force required was excessive. Just wanted to compare with someone else. I know there are other variables like pedal ratio's and calliper piston sizes to consider as well. My clutch feel and travel is excellent with the 3/4" master.
Richard
03-12-2021, 04:48 PM
SA
Yes, the 3/4" and 7/8" F/R sizes are more for competition use rather than road use.
Glen
03-22-2021, 12:00 AM
SA
Greetings!
Steering wheel height is described elsewhere, so will just post the pictures here to keep the build thread 'happy'
Here's a pic of the spacers that determine the height of the steering wheel....
And here's the view ahead over the steering wheel....
Visibility of the speedo and tacho is better than I had expected, and access (to driver's seat) is not affected significantly
Cheers!
Glen
03-22-2021, 03:39 AM
Glen,
Nice to see that this may work. As with most things in life, it is a fine balance between what would be perfect, what we want, what's practical, and what is realistic. The goal is recognizing that there is a balance and not getting stuck.
Take care,
04-12-2021, 01:20 AM
SA
Originally Posted by 1795
Glen,
....a fine balance between what would be perfect, what we want, what's practical, and what is realistic....
Jim, that describes the decisions made regarding a Cobra replica - and particularly one that you build yourself  - extremely well
Cheers!
Glen
04-12-2021, 01:26 AM
SA
Spent a couple of hours out there today. Now have the RHS door catch cover trimmed and fitted.
I intend to cover the inner side of the doors with leather, but still tossing up how to do it. The intrusion bar in the door is nice to have, but makes a door 'pocket' harder to achieve.
The leather strap works nicely.
Cheers!
Glen
04-17-2021, 12:25 AM
SA
I like your new Avatar Glen, great photo, very classy.
Richard
04-17-2021, 03:03 AM
SA
Thanks Richard. It's a challenge to capture good photos in my tiny, tiny garage
Cheers!
Glen
04-28-2021, 11:16 PM
SA
Added (interior) door handles. Non-standard from original, but then doesn't that describe my car?
They are tucked-in well and are not obvious unless you're seated in the car.
Cheers!
Glen
04-28-2021, 11:27 PM
SA
Also, the dash assembly is looking a little closer to the final result.
It's replicating an English car, hence the Smiths gauges.
OK, there's a SW gauge thrown in for good measure
Steering wheel will be used to keep some people happy when it's initially on the road; I have a Moto-Lita split-centre wheel to go in its place.
Cheers!
Glen
