Like Tree390Likes
LinkBack Thread Tools Rating: Thread Rating: 4 votes, 3.00 average. Display Modes
  #621 (permalink)
Old 02-23-2023, 03:52 PM
xb-60's Avatar
Thanks CobraLen. Yes, BJ's car is very, very good.... but mine's better
Good luck with the planning for your build. You're on the right site here (Club Cobra) for the best information and advice available.
Cheers!
Glen
  #622 (permalink)
Old 04-02-2023, 11:30 PM
xb-60's Avatar
Finally some minor progress to report
The flywheel that was originally delivered was the incorrect item. The replacement item (157T) turned up and has been fitted.
The original starter motor - which we thought would fit - doesn't fit, so the correct unit has been ordered. Should be easy to source, but I'll wait and see it actually fitted before getting too excited.
More as it happens!
Cheers!,
Glen
Alfa02 and Harpoon PV2 like this.
  #623 (permalink)
Old 04-03-2023, 12:51 AM
tkb289's Avatar
Glen,
Slow but steady progress, getting the correct parts is challenging and the supply chain issues has not helped. Perhaps you can start to mock up the clutch throwout bearing & fork assembly and slave cylinder mounting, while waiting for the starter motor.
Keep up the good work.
- Tim
289 FIA --- ERA 2136
Build Log:
http://www.clubcobra.com/forums/era-...build-log.html
  #624 (permalink)
Old 04-03-2023, 04:57 AM
1795's Avatar
Glen,
that looks like my bell housing! Depending on the starter, some might need to be clocked and some might need a shim. I had to clock mine to get it to fit.
It's a pain taking the engine in and out, but you might want to get it in place and check clearances before adding too much more to it. Sometimes it looks like something will fit, until you get it in place.
I found that bringing the engine in from the side (over the fender) is easier than bringing it in from the nose (unless you have one of those nice ramps like Shelby had). Most booms lack the reach from the nose and ou are having to muscle the engine back.
Good luck!
  #625 (permalink)
Old 04-06-2023, 01:57 AM
xb-60's Avatar
Tim and Jim,
Thanks, and comments much appreciated.
It certainly does make sense to do a trial fit of the engine with scattershield fitted but without the gearbox to have a 'visual' on the clearance - or otherwise - of the clutch fork. Then any required clearance can more easily be sorted.
Cheers!
Glen
  #626 (permalink)
Old 06-23-2023, 08:27 PM
ssv ute's Avatar
Cobra Make, Engine: ICCARS,6.0LT L98 TR6060
Hi Glen,
Have you had any progress on your build?
Richard
  #627 (permalink)
Old 06-23-2023, 09:00 PM
Alfa02's Avatar
Gold Star Contributor
I'll second that, Glen??? cheers Buddy. Tom.
  #628 (permalink)
Old 06-24-2023, 06:54 PM
xb-60's Avatar
Originally Posted by ssv ute View Post
Hi Glen,
Richard
Hi Richard. Short answer is no.
Longer answer is all is ready to go with trial fitting the engine, and then fitting engine and gearbox as a unit.
Back to the "no"
Went in last Tuesday, as the engine trial fit should have been accomplished. Greeted with - "we don't have the engine mounts". I was about to head home and start searching for them, but I knew I didn't have them, so we started checking all of the gear laid out on the bench that belonged to the car's location.... and there we quickly found the engine mounts. Sheepish looks followed.
So, I'm going back in there this Tuesday.
I need results. I don't want to be too old to drive my car
Glen
1795, Alfa02 and Harpoon PV2 like this.
  #629 (permalink)
Old 06-24-2023, 07:07 PM
Well I remember last year at this time you were at least a year younger.
  #630 (permalink)
Old 06-24-2023, 10:23 PM
xb-60's Avatar
Patrick - I’m not in the mood
  #631 (permalink)
Old 06-25-2023, 05:05 AM
ssv ute's Avatar
Good to hear your build is still going on mate, but understandably I'm guessing your patience isn't doing so well.
  #632 (permalink)
Old 06-25-2023, 06:33 AM
1795's Avatar
Glen,
Yes, it can be very frustrating, especially when little things happen towards the end. We're here for you.
  #633 (permalink)
Old 06-25-2023, 10:02 AM
Alfa02's Avatar
Sorry to hear about the lack of progress Glen, Like Jim said, "We're here for you" It's tough when the Cobra is out-of-your hands, and you feel like no one is doing their job. Like you would being a "Hands on" type of guy. Cheers my Friend
  #634 (permalink)
Old 06-25-2023, 10:20 AM
One day it'll be done. Ehhrrrr, unless Glen is suffering from Cobra-build delusions and there is no car because he's just imagined the whole thing.
  #635 (permalink)
Old 06-25-2023, 08:20 PM
xb-60's Avatar
Positive comments appreciated. It’ll happen.
Incidentally, we’re having our first (local) Cobra club get together for 3 years tomorrow night.
Cheers!
Glen
  #636 (permalink)
Old 06-25-2023, 10:13 PM
Harpoon PV2's Avatar
I know how you feel Glenn! I have a early 1900s motorcycle that I had to use my friends shop to work on it. It's been 5 years now, getting where every day seems like a decade! My only salvation is, those old bikes have shot up in price at an unbelievable pace. A 1908 Harley just went for a cool one million prime cut USD! Believe it or not, I am actually green with envy af your Cobra, scratch that, I'm Jade green with envy! Cheers, Dennis
xb-60 likes this.
  #637 (permalink)
Old 06-28-2023, 08:51 PM
xb-60's Avatar
Patrick -
Just came back from the workshop, and I have some news.
We do have progress...
Engine is bolted in. I will need a clearance hole in the tunnel (edit: for the clutch fork, so will just make up a 'blister' to cover it), but that's not a problem. At least an external slave for the clutch is possible.
....and thank you for those that have stayed with me
Cheers!
Glen
tkb289, Alfa02, rustyrims and 1 others like this.
  #638 (permalink)
Old 06-28-2023, 08:59 PM
tkb289's Avatar
Glen,
Well this is a huge milestone and great to hear that an external slave cylinder is an option. Some fitment issues will surely come up and tweaks that will need to be made, but this is great news !!!
- Tim
xb-60 likes this.
Build Log:
  #639 (permalink)
Old 06-29-2023, 04:53 AM
1795's Avatar
Glen,
Congrats on getting to this stage! There will be some shims here and there that may be required, and measurements will have to be taken after the transmission is in for the driveshaft, but the real hard stuff is behind you.
  #640 (permalink)
Old 06-30-2023, 06:46 PM
BJ's Snake's Avatar
You'll have to buy new tyres now, they'll be out of date!
Progress is progress, good to see.
289 FIA Cobras RULE!
