Like Tree390Likes
LinkBack Thread Tools Rating: Thread Rating: 4 votes, 3.00 average. Display Modes
  #661 (permalink)
Old 10-27-2023, 04:43 PM
BJ's Snake's Avatar
Maybe think about mating the gearbox to the engine and slide it in as one.
I did!
289 FIA Cobras RULE!
  #662 (permalink)
Old 10-27-2023, 06:01 PM
1795's Avatar
If it is possible, putting the two together outside of the car and then installing as one is easier than trying to line up a transmission after the engine is in. Depends on the configuration of the frame and how many helpers you have.
  #663 (permalink)
Old 10-28-2023, 12:14 AM
xb-60's Avatar
Originally Posted by Buzz View Post
She!!
Yours might be a "she", Buzz... I can't argue with that.
Mine, however, is reasonably muscular, most likely will be quite noisy and probably f@rt loadly and often; will emit plenty of fumes; will guzzle 'juice' at an above average rate.
Sounds like male characteristics to me
Actually, my Alfa was exactly the same. From day #1, his name was Luigi.
Here's "cheers" to diversity!
Glen
  #664 (permalink)
Old 10-28-2023, 12:26 AM
xb-60's Avatar
Jim and BJ,
Comments always appreciated.
The engine by itself has been in and out twice to check clearances (exhausts, etc), and also to check the fit of the Toploader (trial fit from underneath) and it was determined that there wasn't sufficient clearance for its side linkages.
Should mention that these are very professional blokes, and they well and truly know how to treat a 'box fitment without damaging or stressing the input shaft.
The plan is still to fit the engine first and do the final fit of the TKX from underneath.
Cheers!
Glen
  #665 (permalink)
Old 10-28-2023, 09:03 PM
Harpoon PV2's Avatar
She!!
Funny, when ever I see a big block Cobra from behind, a certain song by Queen pops into my mind, very female! Cheers, Dennis
  #666 (permalink)
Old 10-28-2023, 09:07 PM
Hi Glen,
What is the plan for the exhaust system?
Do you have some different options, such as having the exhaust exit in front of the rear tire, or are you restricted in what you can run, due to local compliance regulations?
- Tim
  #667 (permalink)
Old 10-29-2023, 06:11 PM
xb-60's Avatar
Hi Tim,
The plan for the exhausts…. my information had been that I would need an exhaust system that exited at the rear of the car, this information being supplied from a supposedly knowledgeable source.
However…. at the workshop last week, discussion turned to the exhaust, and particularly the channels inside the lower side sill panels. These channels are for the exhausts to be accommodated out of sight. My mechanic suggested that the exhausts would/could terminate where most other Cobras exhausts do – in front of the rear wheels.
So, still to be decided. The issue with using the concealed channels mentioned above is that they don’t really look wide enough, and I don’t know where the mufflers could be accommodated. They (the two exhausts) may have to be under the floor like most others, and exiting at the rear.
Cheers!
Glen
  #668 (permalink)
Old 10-29-2023, 06:34 PM
xb-60's Avatar
Which one, Dennis? There are a few that I could think of that would 'fit'
Harpoon PV2 likes this.
  #669 (permalink)
Old 10-29-2023, 10:11 PM
sunman's Avatar
OMG
Only one fits
“Fat Bottomed Girls”
Party On
Chaney Shores Studio
  #670 (permalink)
Old 10-30-2023, 02:18 AM
xb-60's Avatar
Originally Posted by sunman View Post
OMG
Only one fits
Party On
Yep, was thinking of that one, too, but that's 427 cars only, yes?
Buzz and Harpoon PV2 like this.
  #671 (permalink)
Old 10-30-2023, 09:00 PM
427 and 428! Cheers, Dennis
  #672 (permalink)
Old 11-01-2023, 09:49 PM
xb-60's Avatar
Greetings!
Just come home from the workshop. Engine is in, with both front/side mounts now secured. The bottom of the oil pan sits just above the level of the bottom of the 'chassis'
Will need a remote oil filter because of clearance issue with LH exhaust primaries. That's OK.
TKX is positioned, and ready to slide in.
I have made up an adaptor to fit my very nice (and very original looking) shift lever and knob to the TKX - I'm leaving the knob with its 4 speed pattern as per the original 289 cars.
More as it happens ...along with some pictures.
Cheers!
Glen
Buzz, letsboogie351, 1795 and 2 others like this.
  #673 (permalink)
Old 11-02-2023, 04:34 AM
1795's Avatar
Congrats Glen! Not too much longer.
  #674 (permalink)
Old 11-30-2023, 09:03 PM
xb-60's Avatar
Hello all,
As reported in another thread, engine and gearbox are in.
Here's proof....
The car's on the floor at the moment, working on the engine front end, so can't take a picture from the underside, but all is square there.
Here's a picture of the interior...
If you look closely enough, you can see the cover on the front gearshift location that's causing some head scratching at the moment.
Seats have been out, and are just sitting in there at the moment, so their installed location can't be seen correctly.
edit: exhaust primaries are in; final design and routing of the exhaust is still to be decided
Glen
  #675 (permalink)
Old 11-30-2023, 10:32 PM
Alfa02's Avatar
Gold Star Contributor
Damn, Glen the hole looks so nice being filled a powerplant , Cheers my Friend Tom.
xb-60 likes this.
  #676 (permalink)
Old 11-30-2023, 10:42 PM
Glen,
What a wonderful sight to see.
Looks like some plumbing and wiring to do, then figure out how best to mount the shifter.
Any fitment issues with the drive shaft?
Getting closer every day, keep up the great work!
- Tim
  #677 (permalink)
Old 11-30-2023, 10:57 PM
xb-60's Avatar
Originally Posted by tkb289 View Post
Glen,
- Tim
Greetings Tim. Yes, it's been in for awhile now, but the hoist was up, so no pictures available until recently.
Drive shaft? Minor one; the flange was to suit a similar diff to mine but the hole pcd was slightly different. So, set it up on their mill, and machine some new holes. That the drive shaft was quite an easy fit has me still scratching my head about the shifter location. Time to get over that one, yes?
A start on wiring is imminent; lucky it is such a simple setup with no ancillaries. Rather than use the supplied loom, will go with a new loom made from scratch; fitting it should then be very easy and fast
Cheers!
Glen
  #678 (permalink)
Old 12-01-2023, 04:52 AM
1795's Avatar
Glen,
Congratulations and it is looking great! I wish I could help you with the shifter location issue, but I have no experience or knowledge with that transmission. I hope that it gets solved soon. Bye the way, you may want to tighten up that fan belt, it looks a little loose...
xb-60 likes this.
  #679 (permalink)
Old 12-01-2023, 06:54 AM
Wow, it looks wonderful. Yes, absolutely wonderful.
  #680 (permalink)
Old 12-03-2023, 12:39 AM
xb-60's Avatar
That's lovely, Patrick. Thank you.
Trouble is - and don't take this too personally - I still don't know, after all these years, whether to take you seriously or not
Cheers!
Glen
