Old 01-29-2010, 05:06 PM
Black Mamba's Avatar
Cobra Make, Engine: Contemporary Motors, 351W, Richmond T-10 4 speed,
Default Contemporary on Ebay
Too bad it has a Chevy motor
http://cgi.ebay.com/ebaymotors/1965-...t_17958wt_1167
Old 01-29-2010, 07:05 PM
coinop101's Avatar
Cobra Make, Engine: 1985 Cobra 427
Hi
Sorry , I can never understand why anyone would put a chevy engine into a ford cobra ?? To me it kind of defeats the reason of having a cobra , Have you ever seen a corvette with a ford engine ?
Peter
Old 01-30-2010, 10:07 AM
Danr55's Avatar
Chebby engine or no, it's still a good price for a CCX car.
Dan in Arizona
CCX3209
Old 01-30-2010, 10:20 AM
Buzz's Avatar
Default Bottoms up!
People continually refer to Contemporarys as the most accurate (fiberglass) replica ever, but I just cannot get over the high, upturned rear end and sidepipes running below the bottom of the side bodywork. They may have been great quality cars, but these features completely ruin the look of the car for me.
Tropical Buzz
Old 01-30-2010, 11:10 AM
Ron61's Avatar
It has to be the camera angle, but that last picture makes the rear fender look out of proportion to me.
Ron 61
Ronnie Widener
View my Miscellaneous Gallery
Old 01-30-2010, 11:13 AM
There are a "mixed bag", many are very accurate, many are not. This ebay example is obviously not, due to the motor alone. Some CCX came with a solid axle as well, a deal killer for me.
BUT, with many of the early replicas the specs were closer to the original than is common today. Side oiler was a given, for instance, whereas today we see a LOT of small blocks or 385 series engines. That just wasn't an option in the early days, 427 or 428 was the rule not the exception. Interior appointments as well, closer to original specs. In many ways an older replica is a great buy for those looking for a little more authenticity at a good price. Still, one must shop carefully.
I was particulary taken with my personal ERA because of the motor primarily. I liked the original high riser heads, OEM intake and side oiler engine. I also HAD to have IRS and an accurate interior, things you "see" more than things you don't (like the frame) were an important consideration in my book. The body shape in general was also important, Contemporaries are "close enough", FFR and many others are not.
This particular Contemporary wouldn't even be a consideration for myself. I did consider a Contemporary, with a side oiler, just before I bought the ERA. Both were about the same price. The solid axle killed the Contemp deal for me in spite of it's otherwise accurate build, good looks and specifications.
Old 01-30-2010, 03:22 PM
Danr55's Avatar
Camera angles can be deceiving. Here are three photos of the same car from three different angles. It appears that the rear fender lengthens as the camera angle changes.
This is a Contemporary.. or is was before the SUV hit it.
Dan in Arizona
CCX3209
Old 01-30-2010, 04:40 PM
Wow, an impressive example of how the lens can distort your perception.
Old 01-30-2010, 05:53 PM
FUNFER2's Avatar
I can understand mixing different engines, frames and parts with Hot Rods, because guys from the 50's compiled what ever they could get hold of to buikd a car. But not in a Cobra !
That's like putting a Ford FE/side oiler,................in a Corvette !
I know that Rich Anderson (Gessford machine) built a HEMI, for a customers Cobra.
What ever turns your crank,.... I guess.
Kevin
Old 01-30-2010, 06:06 PM
racco's Avatar
I have some experience with the ccx cars. When they were built by the book the rear end of the car is 3 to 4 inches higher than it should be. When lowering the car the neg camber increases from 0 to -3 deg, this reqiuires shimming of the drive shaft in order to attain -1.5 degs.
This one change drives the rear wheels into the wheel well where they belong, you shouldn't see the top of the tire.
Problem number 2, the rear stub axles were widened about one inch ( to increase the track) and this moves the rear wheels out to the fenders. This also makes the car look different. Replacing these custom stub axles with stock jag stub axles removes the extra inch and aids in rear fender clearance.
Thses two mods will help hide or deminish the high trunk look.
Old 01-30-2010, 06:10 PM
racco's Avatar
Also, the side pipes are lower than the "norm". I think the side pipes should be black and that will aslo help. You will never burn your legs in a ccx.
Old 01-30-2010, 06:14 PM
Some engines, like the Hemi, just go well where ever you want to put them. Piece of art in the living room or the man cave, whatever car you happen to have around. I mean you just can't go wrong with any application. I wouldn't even have a problem with a Vette running a Hemi! I'd get a kick out seeing a Ford engine in a Vette, that would be good for a laugh (but thats all it would be good for).
DV put that Viper V-10 in a Classic Roadster with the flip front end, that was pretty cool, very much in keeping with the "hot rod" spirit. Seem's kind of strange putting another brand engine in a Cobra and still trying to keep within the "spirit of a Cobra". Just call it a hot rod at that point, run whatever wheels you want, put in a killer stereo, maybe a video screen between the seats, hang a cow bell from the rear bumper.
Old 01-30-2010, 06:40 PM
jwd's Avatar
jwd jwd is offline
You'll never see a Ford motor in a Corvette. Why? The same reason nobody would put a Chevy motor in a REAL cobra (built in the 60's). You would be destroying the value of the car. The vast majority of Fords built prior to 1950 are powered by Chevy. Why? Because of availability and HP per $$$$. I actually considered a SBC for my Cobra but decided to try something different and built a Ford motor instead. These are nothing more than REPLICAS, put anything you want in them.
Old 01-30-2010, 06:53 PM
We often here that, so where do YOU draw the line? Why not raise it and put 4WD Subaru guts in it? Red crushed velvet seats anyone? 24" wheels maybe? After all, it's "just a replica". You WILL draw the line somewhere, I'll draw the line at Chevy engine because to me it's MORE than "just a replica", it's a connection with history.
Old 01-30-2010, 07:00 PM
jwd's Avatar
jwd jwd is offline
Personal preference. Nothing more. It will never be an original Cobra regardless of what you do to it. Like I said, if it wasn't built in the 60's, it's just a copy of an original. Call it a REPLICA, CLONE or even a TRIBUTE, it is just that, nothing more.
Old 01-30-2010, 07:10 PM
*13*'s Avatar
Another Ford/Chevy fight? Someone go out & get popcorn!
Little better fit on the tires, maybe a little smaller, lower the rear & it would probably look pretty damn good. I think I'm gonna come up with a valve cover & Distributor conversion kit for you chevy guys
ERA FIA 2088
Old 01-30-2010, 07:14 PM
jwd's Avatar
jwd jwd is offline
Not really, more of a "I have a replica but think it's real, fight"
Old 01-30-2010, 07:38 PM
berzerko's Avatar
Cobra Make, Engine: hurricane 1075
what if shelby contracted someone to build it?
I know your answer but many here would beg to differ
Bobby
Old 01-30-2010, 07:42 PM
I always wondered why they're called replicas and not reproductions which to me has a slightly more dignified sound. Whatever, either way it's a knock off and that is what I have till I win the lottery and even then I will probably still have a replica or reproduction because I'll have a lot more fun then tooling around in an original.
Old 01-30-2010, 07:52 PM
jwd's Avatar
jwd jwd is offline
Originally Posted by berzerko View Post
Bobby
I don't care if the old b*st*rd hand built it himself, it would still be a replica of the original and the value would reflect that.
