Go Back   Club Cobra > Manufacturers, Engine Builders, tools, and parts. > Contemporary Classic Forums
Old 08-28-2010, 09:35 PM
Default Contemporary unfinished kit value
Here is the car, still in factory gel coat. torsion frame, front suspension, windshield, side pipes, seats, dashboard, 3:73 posi jag, lower control arms,
Darn it, how do you add a picture? It says upload failed,
Old 08-29-2010, 04:45 AM
Danr55's Avatar
THe photo is probably too big. Reduce the size and try again.
Dan in Arizona
CCX3209
Old 08-29-2010, 09:33 AM
Okay, I tried to reduce the pictures, well you have to be smarter than the machine...didn't work. so I tried to set the camera instead. It worked!
So here's the question.
Sell the Contemporary Cobra Factory gel coat black, torsion bar frame all painted high gloss black, windshield, factory side pipes, front jag suspension all finished black with teflon bushings, wilwood brakes, new rotors, rear 3:73 posi, lower control arms, hub carriers, new rotors, half shafts, ( missing hub and stub axles), dash board, seats, steering wheel and column and misc.
Old 08-29-2010, 10:31 AM
767Jockey's Avatar
Do you have the MSO paperwork for the kit?
Old 08-29-2010, 11:51 AM
Do you mean paperwork from Lynn Parks/ Louis Downs and Peter Bayer when I purchesed it. The Body, windshield, side pipes, dash, door strikes, hood scoop,were purchased in I believe 1994. The frame and suspension were purchased later. Originally I was building my own frame and times changed and went to factory components
Old 08-29-2010, 02:04 PM
1985 CCX's Avatar
Price sheets included.......already discussed of course not accounting for inflation.....
Help, whats the value? kit never built
Old 08-29-2010, 05:31 PM
Danr55's Avatar
I thought you said it didn't have a dash in it yet? Sure looks like a dash to me..
Dan in Arizona
CCX3209
Old 08-29-2010, 05:56 PM
mickmate's Avatar
SPF vs CCX
mickmate
http://www.actoncustom.com/
Old 08-29-2010, 06:36 PM
racco's Avatar
I'm interested in the kit, is the hood uncut? If so pm me with the details.
Old 08-29-2010, 07:24 PM
yes it has the dash, dont no when I wrote it didnt', oops. yes the hood is uncut, still original. Thanks again for posting the price list, I did find mine but it just reminds me what I paid without the jag suspension. went thru my stuff and I found std bore 427 pistons to go with the block, crank and rods. Would any one run HIgh rise heads with a single four on the street? Or would they rather have J low riser heads?
It seems to add up fast math about 12k, assuming about 1500. for suspension, is that what it's worth do you think?
Thanks
Daniel
Display Modes
