February 2026
Old 01-03-2011, 03:02 PM
Danr55's Avatar
Default A question about Tie Rods
Has anyone ever had one break? I had one break while making a left hand turn on Sunday. It simply snapped right behind the ball that hooks up to the steering rack. I've never heard of anything like it. Has anyone else?
Dan in Arizona
CCX3209
Old 01-03-2011, 03:07 PM
I have seen the ball come out of the socket and i have seen them bend until they break but never had one just break into 2 piececs before....i think Speedway sells a heavy duty version of the Mustang 2 tie rods....if thats what you have...
Old 01-03-2011, 04:26 PM
dave from mesa's Avatar
Cobra Make, Engine: FFR from Levy Racing 302 FI w/Edelbrock Performer heads
He should have said that it is a Jag front end.
dave from mesa
Vietnam Vets may be eligible for medical care and disability compensation. Contact the VA if you have prostate cancer or type 2 diabetes. Finally got around to going to the VA.
Old 01-03-2011, 04:31 PM
i guess that would make a difference...........
Old 01-03-2011, 07:31 PM
racco's Avatar
Default tie rod
Did you know that the tie rods are welded together on a ccx. If you look in the assmbly manual it will explain it all.
Old 01-03-2011, 07:55 PM
mickmate's Avatar
They were narrowed for CCX's as Racco said and welded back together. I have replaced some steering shafts that were also shortened and welded back together. Boy did they look scarey. Good point Dan I hope our CCX boys look them items over real good as some builders did some questionable work on them.
mickmate
http://www.actoncustom.com/
Old 01-07-2011, 05:32 PM
Danr55's Avatar
I received the new Jag tie rod today and it is much beefier than the old one. I notice, however that it is undercut immediately behind the ball. I guess that's for clearance, but that is exactly where the old one broke.
Dan in Arizona
CCX3209
Old 01-08-2011, 11:04 AM
Danr55's Avatar
I also just found out that the Jag tie rod is about 1 1/2 inches shorter than the CCX tie rod. Anyone out there have any suggestions?
Dan in Arizona
CCX3209
Old 01-08-2011, 11:24 AM
Karl Bebout's Avatar
Find a good welder....not me.
Karlos
Old 01-08-2011, 11:46 AM
MOTORHEAD's Avatar
Dan : there are extensions out there, basically a short section of hex material with female threads and male on the opposite end. I think their on my Kirkham rack (MG Rack). of course you'd need to find some the right size and thread, Shouldn't be to hard to fab up at a local mach shop.
Ted
"When Injustice becomes Law,
Old 01-08-2011, 11:53 AM
Danr55's Avatar
Check this out. You can see where the original has been cut and had a section welded in.
Dan in Arizona
CCX3209
Old 01-08-2011, 02:06 PM
mickmate's Avatar
Reminds me of the Ghostbusters song "who ya gonna call" ;-)
mickmate
Old 01-11-2011, 05:57 PM
Danr55's Avatar
Who ya gonna call? Mickmate.. if you find those other two tie rods, I'll buy those also just so I have some. THanks Nick.
Dan in Arizona
CCX3209
Old 03-01-2011, 04:47 PM
Danr55's Avatar
Well, the story continues. I got some new tie rods and got them to Nick to lengthen.. they fit fine by the way, Nick.. So I took off the one that didn't break, just as a safety measure. Check out the photos.. It didn't have long left. I don't know if it's something specific to my car or the way I drive, but this is scary. If I had a Contemporary with about 30K miles on it, I'd be checking the tie rods out carefully..
The worn spot is clearly visible. This thing could fail at any minute.
Dan in Arizona
CCX3209
Old 03-01-2011, 05:25 PM
azfordman's Avatar
Cobra Make, Engine: CCX-3-3624, 351w, 5-speed
Dan, aside from obvious cracking, what am I looking for? Looking at photo #1, are you saying the tiny ding at the bottom of the ball would cause it to snap off? I have not looked at mine yet, just trying to get a grasp on what I should be looking for. Have you found this to be a common problem with CCX's in general, or only an isolated incident with your car?
"Freedom is only an illusion when the government has all the guns."
Old 03-01-2011, 07:28 PM
Danr55's Avatar
Mark, I don't know about anyone elses car. I just know about my car. The tie rod that broke and the tie rod that almost broke. Given the potential for a catastrophic failure, I'd at least check it out.
Dan in Arizona
CCX3209
Old 03-02-2011, 09:44 AM
mickmate's Avatar
Hey Dan, it looks like the steering is turning further than the joint can handle and bottoming out. That indent sure would propogate a crack right where the section is narrowest. I wonder if the CCX is missing a steering stop that was on the frame of the E types?
mickmate
Old 03-02-2011, 12:18 PM
azfordman's Avatar
Nick, perhaps you can explain what we should be looking for........
Old 03-02-2011, 12:59 PM
Danr55's Avatar
Mark, The small "ding" that you see in the photo is a section of the forging that has blown off the tie rod. That is generally a sign that the material has been stressed. It's not worn or broken, but the metal has compressed and a piece has litterally exploded in a small area. The way the steering is designed, I don't thing oversteering is an issue. The balls are on the inboard end of the tie rods. It the car oversteered, the pressure would be on the outboard end of the tie rod. So I can't say for sure what's going on. I've asked a NDT guy at work to have a look and I'll be interested to see what he says.
Dan in Arizona
CCX3209
Old 03-03-2011, 01:47 PM
mickmate's Avatar
That's Non Destructive Testing for guys that don't work in the engineering field.
mickmate
