Go Back   Club Cobra > Manufacturers, Engine Builders, tools, and parts. > Contemporary Classic Forums
Like Tree1Likes
  • 1 Post By Dominik
Old 08-24-2020, 03:20 AM
Dominik's Avatar
Default Contemporary body off ground measurements
Good morning!
I pulled the body out of my mould now and pre-fitted it to my chassis. Since I have tub and main body separate, I am looking for measurements to find how far the rear is above ground.
If someone could check for me:
sill (sides) above ground
and rear above ground
For owners with sidepipes it might prove to be easier to measure the leading edge of the rear fender. Or even more sexy, the angle of the rear fender.
My ground clearance to chassis in the rear, at the end of the main rails, is currently 5".
1985 CCX likes this.
If I don't respond anymore, that's because I can't log in
Old 08-25-2020, 10:27 PM
Dominik's Avatar
I placed the rear fenders 650 mm off ground with the chassis having 160 mm clearance. That sounded like a cool measurement to me. 666 mm would have been even more cool, but not as low ;-)
Old 08-31-2020, 07:21 AM
Cobra Make, Engine: MidStates, 351C, 4spd, 9"
Send a message via AIM to krausewich
Hi Dominik,
Measuring to the undersides of the wheel arch lips, to the underside of the nose opening, and to the bottom edge of the trunk opening should put you pretty close to where you need to be. Make sure which Contemporary body you have as well, because I believe they changed their wheel flairs to wrap closer around the tires at some point.
Best of luck!!
Mike
"It's not about getting from point A to point B. It is the point"
-J. James
M. Krause
1.508.944.3368
Old 01-17-2021, 02:14 PM
Eljaro's Avatar
Cobra Make, Engine: Contemporary with 482 KC/SO, TKO600,IRS Jag/AMP, 3.54 Salisbury PL,
My contemporary with 245/60-15 front and 295/50-15 rear tires measures from ground to the wheelarch lip 655mm in front and 675mm in the rear.
Nothing sounds better than a Cobra in a Tunnel !
Old 12-02-2021, 12:59 AM
Dominik's Avatar
Okay, since I managed to log in today and have the car on wheels I had 630 mm in the rear which caused the under car exhaust to touch too often. I raised to 650 mm. And 670 mm in the front.
My rear tires are quite far in because I use the original suspension layout. What I should have asked for is the width of the body under the seats. Before I cut and glued the tub in.
235/60/15, 275/60/15
