Go Back   Club Cobra > Manufacturers, Engine Builders, tools, and parts. > Contemporary Classic Forums
Old 10-23-2022, 07:04 AM
Default Dash removal
Anyone have any tips for removing the dash to work on instrument cluster? I see the steering column goes though the dash so I assume that has to come out first. From there it just looks like a couple of screws on the top along the dash?
Thanks.
Old 10-23-2022, 10:38 AM
Mongoose930's Avatar
Cobra Make, Engine: Hi-Tech
This is how I did mine.
Old 10-23-2022, 12:12 PM
When you remove the five dash screws you can tilt the dash back towards you and do a lot of work behind it by coming down from the top. I've changed out gauges that way without having to disconnect anything else. If you want to pull the dash completely, you're going to have to remove the steering column, any tight wiring connections to the gauges, ignition switch, other switches, etc., disconnect the vent cables, the water and temperature mechanical lines, the oil pressure line and however your glove box is fabbed in there.
Old 10-23-2022, 03:42 PM
Did you leave the steering column in and just remove the wheel? Did the doors need to come off?
Thanks
Old 10-23-2022, 03:47 PM
xb-60's Avatar
Thanks.
First question is.... which replica manufacturer made your car?
Glen
edit: I missed that it is posted in the Comtemporary forum
Old 10-23-2022, 04:27 PM
It was 10+ years ago, but as I recall, the doors stayed on. The steering wheel and hub were removed, but I did not take the steering column out, just disconnected it at the dash and let it drop. This was also a Contemporary.
