Old 04-23-2009, 07:14 PM
Danr55's Avatar
Default Lesson learned
As some of you know, I've been chasing a shake in the front end of my car for some time now. Well, I've found the cause.... and it has nothing to do with the front end. I had a warped hub on the right rear axle. I've found a replacement for it and should have the car together in time for the Rt. 66 fun run next weekend..
Just a hint, things are not always what they seem..
Dan in Arizona
CCX3209
Old 04-23-2009, 08:36 PM
DocDirk's Avatar
Cobra Make, Engine: West Coast-Ford Performance Solutions 533 BB
Thanks, that's the kind of thing that can drive one nuts and be expensive to troubleshoot! Back in the 80's when all I know about cars was where to put the key, I had a right rear knocking noise in my 1962 Jag Mk II sedan and no amount of shops' "fixing" of the rear end or suspension made any difference. A seasoned pro in Walnut Creek at Perry's Jaguar asked for a ride before tackling the problem and a mile or so down the road announced "you have a loose engine mounting bolt"...... and proceeded to fix it which took care of the "rear end" knock! .... the value of experience, thanks for sharing yours Dan
Dirk
The government giveth and the government taketh away..... if our rights are not God given then they're subject to revision!
