07-14-2011, 01:44 PM
FR
Cobra Make, Engine: Kirkham 427 S/C (KMP304) / 427 FE S/O stroked to 428ci (CSX460) / Weber 48 IDA's
Is there a way to contact David Kee ???
I have a problem with my transmission and I have been desperately trying to contact David Kee (several emails, phone calls, messages on the answering machine... since nobody seems to pick up the phone !). I live in France. Do you know if they all left on holidays ? If the company still exists ? Is there a "secret" phone number I do not have ???
If somebody could help me to contact them I would be very grateful !
See below the explanation of the problem I m having with my Kirkham :
Toploader Oil Leak.. Help !
Emmanuel
07-14-2011, 01:48 PM
KY
David Kee is not the only one that works on Toploaders....
I'm a McLeod dealer and I can get whatever parts you need for your hydraulic throw out bearing. Do you have any part numbers?
07-14-2011, 02:07 PM
FR
Unfortunately no and that is my problem.
I know exactly what the problem is, but because I do not have the part numbers I need advice before I can order.
Can you give me your phone number !?
Thanks for your help.
07-14-2011, 02:09 PM
FR
07-14-2011, 02:11 PM
KY
What advice do you need? I have a feeling that your french accent and my Kentucky redneck accent probably won't be too compatible.
If you need parts for the hydraulic bearing that you have, I know which McLeod bearing you probably have. It's a bolt on hydraulic bearing, correct?
07-14-2011, 02:15 PM
KY
Since you have a Kirkham car, how about using a regular clutch fork, throw out bearing, and hydraulic slave cylinder? I never recommend hydraulic bearings to anyone...and you're experiencing the reason why. In the long run, it would be much cheaper to switch.
07-14-2011, 02:26 PM
FR
I agree with you 1000% !!!
I have been trying to understand what I exactly need for more than 10 days.
It's very important what I need so has not to forget anything (seals, screws, bolts, fork, slave cylinder, centerforce (?)... etc).
Did you see my post ? Toploader Oil Leak.. Help !
In case you need it, my bellhousing (to fix the fork I suppose) is a Lakewood blowproof bellhousing.
07-14-2011, 04:13 PM
KY
The only slave cylinder that I have to work with a Toploader and a Lakewood bellhousing is a Wilwood slave cylinder. Unfortunately, you would have to fabricate your own bracket. Otherwise, the parts are readily available and ready to ship.
As an example, you would need:
(1) MCL-16915 - T-Bracket - $38
(1) MCL-16935 - Clutch Fork- $62
(1) MCL-16042 - Throw Out Bearing - $65
(1) Wilwood Slave Cylinder - $80
If you wanted to try to get parts for your current hydraulic bearing, I'm pretty sure it's part number MCL-1305. If so, there are replacement parts available:
McLeod Racing - Replacement Parts for 1300 & 1400 Series Bearings
If you knew exactly what you needed and wanted to go this route, you could email me with the part numbers, I could get you pricing, and then send the parts to you.
07-14-2011, 04:31 PM
I'm sure I remember one of the Kirkham brothers posting shots of a beautifully crafted "traditional" fork/external slave system that they had put together. C'mon, most (not all) of the HTOB owners on here have complained that they were basically a POS (certainly the early ones were).
07-14-2011, 04:42 PM
KY
You are right Patrick....I think the Kirkhams do have their own slave cylinder/bracket kit.
You are also right about HTOB's being less than desired. The regular clutch fork method is much cheaper and much easier to work on.
07-14-2011, 04:52 PM
Mike Forte is another option -- he's probably got one sitting on a shelf behind his desk that he could ship out tomorrow.
07-14-2011, 05:19 PM
KY
Ah c'mon Patrick.....promoting the competition? Where's the loyalty brother?
07-14-2011, 11:53 PM
Brent is on top of his game, desmo... you can trust him to hook you up!
Paul
Unique Motorcars 289 USRRC
1964 289 5-bolt block
Toploader and 3.31 rear
