Go Back   Club Cobra > Manufacturers, Engine Builders, tools, and parts. > David Kee Toploader Transmissions Inc. Speak with David.
Old 12-18-2002, 03:44 PM
Default David McKee
A post was made about a Gear Vendors (tailshaft/electric overdrive unit) for racing applications. Would unit work for CR toploader street/higway application on a FE powered Cobra, Mark III Chassis?
http://www.gearvendors.com/racing.html
TIA
Gary
Old 12-20-2002, 06:25 AM
Default Overdrive
I talked with gear vendors at the SEMA show this year. It would work fine but it will be too long for a Cobra. We talked about making a shorter shaft and tailhousing to adapt to their unit and make it shorter overall. I am so heavily involved in reproducing the rest of the transmission I have not had time to look into the overdrive more.
Old 12-20-2002, 08:46 AM
Ken Oikawa's Avatar
The price for the Gear Vendors unit 3D6000 is $2495.
When you add in the price for a Toploader, you can almost buy a G-Force 5spd.
Copied from Gear Vendors
" 3D6000 Custom Ford Top Loader/Jerico 4-Speed Racing Trans. Replaces 9 1/2" tail housing. Requires bearing plate, (included). Ford Top Loader/Jerico 4-speed manual racing trans. Specify if using rear end pump. "
Old 12-20-2002, 09:39 AM
Default David
Thanks for the reply. Yes the toploader parts are the most important.
Display Modes
