  #22 (permalink)
Old 06-05-2004, 07:46 PM
UPDATE: Coupe is alive and drove from the shop right to a car show tonight and then home. Found a Crane steel disributor gear for the old Accel dual point distributor: we needed a .5 diametre hole for the shat (an unusual size): otherwise we were going to have to go with a whole MSD ignition et up to the tune of $500! Did everything for about $1600 including salvage Explorer engine,
labor, gasket set, oil for 2 oil changes, plugs etc.
And it runs like wild! MUCH FASTER!
wwe are going to tear down the old engine and see what's wrong: we believe it was the cast distribtor gear eaten up by the hardened roller cam gear: A roller cam calls for a bronze or hardened steel distributor gear. The gear we took out was really chewed up.
We may rebuild the old engine as a spare and sell off the fuel injection etc to off set the cost of the rebuild.
Thanks for all the help-see you at the Willis! cb
Display Modes
