10-15-2009, 04:38 PM
Ct
grease fitting access
I did an oil change and grease job on 2041 last weekend. I could access all the grease fittings except the driveshaft. Any advice on how to get to them from underneath, or does the tunnel have to come off ? The car has 39,000 miles, so how important is it to grease the driveshaft u-joints.......how often do you guys do this? thanks
10-15-2009, 04:55 PM
It's really important to grease them, and the front drive shaft u-joint can be a real bitc_ to get to. Here's a Spicer video I posted a couple of years ago showing you the proper method of purging the four posts. http://ujoint.kickme.to You should purge them at least every 10,000 miles or so. Since you can't get to it from beneath, I would first try removing the four screws that hold the shifter boot ring and see if you can get to it with a longer extension through that hole. If you can't do it that way, then your next option is to remove tha passenger seat and cut a small access panel under the carpet and through the tunnel. That would be pretty quick and easy. Your final option is to remove the tunnel.
EDIT -- What's blocking the rear drive shaft u-joint? That one is usually easier to get to, at least on my car -- FIAs must be different.
Reason: Added additional thought
10-15-2009, 05:24 PM
Ct
Wow, there's more to it than I thought. When I couldn't see the front u-joint, I didn't try to see the rear. And, I didn't have the car very high on jack stands, so it was hard to get a good view. I'll try again at next opportunity, per your suggestions. Thanks for the quick reply.
10-15-2009, 05:28 PM
I think you'll find the rear one to be pretty easy -- it is on my car. And I think with a long extension and a swivel head that you can get the front one via the shifter boot hole. Somewhere I've got a picture that I took of the front u-joint through the shifter boot hole. I'll see if I can find it and post it.
10-15-2009, 05:34 PM
Here's a Shot
OK, this is what it looks like through the shift boot hole. I think you can do it:
10-15-2009, 06:21 PM
Ct
Fantastic! Thanks for the help and photo, I really appreciate it.
04-20-2010, 05:14 AM
MD
I did some annual maintenance last week (loose fastener check, suspension/drive train grease, pull all wheels and apply anti-seize). I don't think I had any grease fittings on my drive shaft u-joints and just wanted to double check that I didn't forget/miss it. The CSX cars have greaseless u-joints for the drive shaft, right? Of course I could go out and check, but this seemed like an easier option.
www.partskeeper.com
10-15-2009, 07:56 PM
Cobra Make, Engine: Superformance 2765 Roush 427(POS) with cruise.
patrickt,
I'm in awe at your knowledge, experience, patience, and cool at which you answer a lost soul's dire questions.  I'm new to this forum and a new owner also and am one happy dude to have people like you answering our seemingly difficult questions. Actually there are several of you but you seem to come to mind. Thank you.  209
10-16-2009, 04:13 AM
Originally Posted by 209
patrickt,
Yes, I think both RodKnock & ERAChas will agree with you that I am indeed the salt of the earth.
10-16-2009, 04:50 AM
MD
Modest too...
www.partskeeper.com
10-16-2009, 05:25 AM
SALT is not the term that comes to my mind...
And you Rod?
Chas.
10-16-2009, 06:35 AM
Sugar, perhaps?
10-16-2009, 04:44 AM
Next time I have access to a car-in-progress with a visible driveshaft, I'll see whether I can build in an access hole for the front grease fitting. I've got a top-view picture of a Richmond Gear setup and it looks "interesting" for an oval hole that covers the varying length of the shafts necessary for all the transmissions that we support. It's pretty close.
Alternately, maybe a hole in the tunnel with a snap-in plug (with a piece of carpet glued on) might be the best approach.
10-16-2009, 05:29 AM
GA.
You could always install a set of Ford u-joints that do not have a grease fitting. No need to grease them, just replace them about every 150,000 miles.
10-16-2009, 06:33 AM
Everything that I have read from Spicer (and other manufacturers) seems to indicate that for our Cobras the greaseless u-joints would be just as good, if not better, than the greasable ones. But it's easier now to just grease them than it is to replace them.
10-16-2009, 07:22 AM
I will ask our driveshaft expert whether he thinks that a permanent (greaseless) joint would work better in our situation.
10-16-2009, 07:33 AM
Ill
The permanent ones are better because they are stronger, the fact that you don't need to grease them is secondary
10-16-2009, 09:00 AM
ID
Cobra Make, Engine: Contemporary Classics 427 SC, 427 sideoiler
The greaseless u-joints are a good way to go if you have access problems. On my Contemporary, I have easy access to the rear and I can drop the drive shaft out in 10 minutes time for the front. So, I've stuck with the greaseable guys. I will probably change if they need replacement.
10-16-2009, 02:59 PM
Cobra Make, Engine: ERA #629, BBM Side Oiler Block, 482ci, Richmond 5 speed
I went greaseless after this happened:
This was a Spicer u-joint with only about 15 or 20,000 miles on it.
10-16-2009, 03:32 PM
Ct
Now I'm wondering how the greaseless design can get 150,000 miles.......what magic allows that? Must be newer technology grease......thanks again to all of you for the sharing of knowledge and experience. That last photo is worth 1000 words. I assume it gave no advance warning, or you would have done something......I expected I would hear or feel something.
