Like Tree2Likes
  #41 (permalink)
Old 11-05-2009, 05:14 PM
ZOERA-SC7XX's Avatar
I had the same problem two years ago when I bought my tank from ERA. When I mounted it, and it interfered with the MSD distributor, I asked Doug what to do about the problem. He just said he puts a pry bar between the tank and the block and gently 'tweaks' it away until he gets the required clearance. I did just that and although it's close, I've had no problems since.
Although the photo isn't a close up, it shows the relative 'tight squeeze' of the tank and distributor. I'm able to adjust the timing without any problems.
  #42 (permalink)
Old 11-07-2009, 06:21 PM
Cobra Make, Engine: ERA 427 SC with 428 PI
I have the same set and had to make a spacer too, similar to the one in the photos, not a big deal to make.
"Is it original ?" -- " Yes! But some parts are new."
It's just easier this way.
  #43 (permalink)
Old 01-05-2017, 01:59 PM
Thumbs up
Originally Posted by lineslinger View Post
Without the spacer the edge of the E tank was just barely resting against one of the electrodes on the dizzy. It wouldn't take a much time for engine vibration to allow scoring of the rubber boot from the seam on the tank. As well I use the same oval air cleaner without problem.
This is the distance I accomplished
I had the same problem with an Accel distributor and the Header tank. This thread resulted in me finding I had a spacer wedge supplied that wasn't flat, (so had leaked coolant everywhere)
So, just a quick thank you to all those that contributed to this thread some time ago, especially Lineslinger. Inspired, I went out and bought a drill press, and made my own spacer. I now have clearance issues resolved for various connections and can now spin the vacuum advance without scraping the header tank.
Great to have forums like this one!
Crendon 427, in the making
http://crendonreplicas.com/
