26Likes
04-08-2012, 10:38 AM
Originally Posted by strictlypersonl
If you do that, just remember that not all hose is DOT-approved. Inspections, and all that...
Using your computer to print out "DOT Approved" stickers, and then wrapping them around your brake lines, does wonders to avoid that pesky nuisance....
04-08-2012, 11:00 AM
How come you didn't tell me that when you sent me the big brake kit and steel hoses (16? years ago) Robert???
Chas.
04-08-2012, 11:33 AM
Ignorance is bliss.
The good part is most companies now offer the DOT-compliant hoses. That's what we've been supplying for about 10 years.
04-08-2012, 12:22 PM
Ignorance is bliss.
It never bothered me---witness non-DOT harnesses, tires and brake hoses. Funny how stuff engineered for the stress of racing isn't deemed suitable to be legal for street use...Lotta geniuses in BIG GOVT...
Chas.
04-08-2012, 02:41 PM
As far as I can tell, the only change in the hoses is some reinforcement where the line enters the end fittings. I suspect that it's supposed to idiot-proof the system so that hanging the caliper by the hose won't damage the line.
04-14-2012, 03:00 PM
Well - I finally have 4 wheels mounted although I'm a long way from going anywhere yet.
As some suspected I might - I have a little intererence with the rear of the front wheel well lip on the driver side with the 26.9" tall tires. It's not much and might even miss with the suspension at ride heigth (and maybe not) but it looks like I'll have to shave a little off the lip there and get our my air brush for a little touch up. I'll wait until I get the motor/trans in, the suspension is settled some and I can adjust the caster which is at who-knows-where right now. The passenger side clears by about 3/4 inch. There's that "asymetrical" body again. In this picture I've turned the tire to the point it hit the lip. From the photo perspective it's hard to see the wheel is cranked around.
04-14-2012, 05:12 PM
Yes, you're well on the way. I was there several years ago too, but the build time flew by and before I knew it I was on the road. Good luck
04-14-2012, 06:16 PM
Cobra Make, Engine: ERA #766, FE V8, Toploader
Dan - you're front and rear tires appear to be different sizes. Aren't you building the street model?
Your paint job looks great!
04-15-2012, 04:43 AM
Yes and yes - it's a story of compromise. At the time I started Sumburst wheels were basically unobtainium (at least pricewise). The wide-hip street car body with 7-1/2 inch rear SC wheels all around was not my favorite look and Peter discouraging me from going with a widened rear suspension although in hindsight that might have been something I should have done as I would have gained room for the exhaust also. Also, although no stranger to fiberglass work having restored an old Corvette, I wasn't brave or disrespectful enough to start carving up the beautifully done ERA body to create a narrow-hip version. So, I ended up going with the wide-hip Street Cobra approach + day 1 (or day 2) when a lot of early owners switched to 7-1/2 & 91/2 SC or FIA wheels in order to fill out the rear fenders on the wide-hip models. Next, I had to go with something smaller in a tire in the rear so I can fit 2-1/2 inch tail pipes back there (ERA only uses 2 inch) which I wasn't willing to compromise on. A 255/60-15 tire came closest to fitting the bill and being tall enough to fill the wheel well. It was a little marginal in size for a 9-1/2 inch wheel but I like how it worked out. In picking a front tire I again wanted something fairly tall and the 60 series sizes just didn't size up like I wanted, so I went with a 215/70 tire that fits on a 7-1/2 wheel marginally about the same as the rear tires - giving real similar sidewall appearance. BUT - it's a 26.9 inch tall tire (virtually the same as rear) and about 1/2 inch larger than ERA recommends. Thus - I was watching for tire rub on the fender lip at the rear and sure enough on the driver side there is a little bit.
ERAStreet went with a different approach and he has a beautful car that is the wide-hip Street Roadster + day 0 with his Sunburst wheels all around. But, I wanted to fill the rear wheel wells with a little more tire and have big exhaust.
So, there - any of you future Street Roadster builders - are two general approaches.
Dan
04-15-2012, 06:26 AM
I know it wouldn't be cost-effective for ERA to gear up separately for a narrow-hip 427 street roadster body - just not enough demand apparently. But - I wonder if they have ever considered moldiing up a set of outer rear fender sections matching the narrow hip car that would extend to the mold match lines surrounding the rear fender flares and wheel lips. If they included a recessed bonding flange it would be pretty easy for anyone with a little fibergalss skill to zip the SC fender section off at the mold lines, bond the new narrow-hip fender sections on and then dish grind and fiberglass everything together. They could sell them as an owner-installed option or even do it themselves.
Maybe something for Mr. Bruce to consider doing for ERA, FFR and Shelby fiberglass bodies.
Dan
04-29-2012, 10:16 AM
Street Cobra Gas Cap
I've been trying to figure out some sort of rubber grommet to use under my street roadster gas cap. (I know - it has a ribbed release button and isn't 100% original as a result). I finally went and rummaged through the plumbing department in Home Depot and found this one. The originals didn't use anything quite this finished from the pictures I've looked at - but this works so well and looks so good that I'm going to stick with it.
Does anyone know the correct orientation of the gas filler (hinge in back or front). Most seem to be installed with the hinge at the front but I have a picture of 428Street's car and it appears to have the hinge at the rear. I know how thoroughly he has researched original details so I'm left a little perplexed on this.
04-29-2012, 01:54 PM
My picture of csx3360 shows the release button toward the back of the car.
04-29-2012, 01:58 PM
OR
Dan
I like the idea! More options for us picky types...
ERA FIA 2088
04-29-2012, 02:00 PM
I think I'm going to flip it around to that direction. Makes sense somehow.
05-28-2012, 10:37 AM
06-04-2012, 06:47 PM
Did your transmission tunnel arrive with the ashtray hole already cut?
06-05-2012, 05:02 AM
Cobra Make, Engine: BRG ERA street car w/428 PI, Sunburst wheels, undercar exhaust, original interior, no philips head screws!
Not sure on Dan's car but 99% no since there are very few street cars built...Dan, the snaps for the top of the pocket (2 on each side) should be lift o dot's not the black ones you have that are stock. Either is fine but if you want the small details you have it!
06-05-2012, 05:11 AM
Dan:
My orientation is wrong!
06-05-2012, 05:12 AM
Any idea why they even have snaps or lift-o-dots at the top of the pocket? Does it flap on the highway or something? I didn't test fit my side curtains to see if they would fit in there - it looks a little tight and I bought a storage pouch from ERA to store them in, in the trunk. But I wondered why the snaps?
Dan
06-05-2012, 05:14 AM
Yes it did. I ordered it as an option so I they did the prep. I don't smoke - just another item towards period appearance.
