Old 07-19-2010, 06:34 PM
Cobra Make, Engine: ERA 427SC FMS 351W
Default Mounting new Holley Fuel Pump in ERA
Bob, any advice on mounting a new georotor fuel pump from Holley HP 125? I believe the new pump is a little heavier than the old electric pump. Should I mount two alumimum plates to either side of the fibergrass trunk side panel first?
I plan to install the Fram HPG filter between the tank and the pump and a pump relay to ensure full battery voltage to the pump.
Old 07-20-2010, 04:13 AM
Large OD washers would do the job too.
We usually mount the pump directly to the side of the frame rail with threaded inserts.
Old 07-20-2010, 07:33 PM
Default Threaded inserts??
Bob, I have not used threaded inserts. What are these and how difficult are these to install?
Old 07-21-2010, 04:00 AM
There are insert installation instructions in the manual in the bumper installation section for "Retrofitting the front nudge bar". I'd recommend using something like McMaster Carr's part # 98560A571.
Old 07-22-2010, 10:04 PM
PANAVIA's Avatar
Threaded inserts are the way to go, --get the tool to install them properly and pay close attention to drill size and angle.
