Old 06-08-2011, 09:10 AM
Default Challenge for ERAChas...
... or anyone else, I suppose, except Bob. OK, Chas... tackle this one: You're out in your ERA Cobra, and you lose your ignition key. The only tools you have are a screwdriver, and a three inch piece of wire (ends conveniently stripped). It's too dark for you to see or feel for the back of the ignition switch behind the dash (plus your back is out), so you can't do it that way for this exercise. Using nothing more than your three inch piece of wire and a screwdriver, how would you hotwire and start your car in one minute or less? Mind you there are no "sneaky word-tricks" to this; you should be able to do it with just the one piece of wire and screwdriver. Also, the solution must work regardless of whether you're running an original points/condenser system or a new style MSD or Mallory electronic ignition -- and you can't "steal a wire" from somewhere else on the car, either.
Old 06-08-2011, 09:14 AM
kgs365's Avatar
Default Why is this a good idea?
is this really a good idea ...its like telling everyone here is a where I hide the key to my safe.
Old 06-08-2011, 09:20 AM
392cobra's Avatar
6th Generation Texan
Connect wire from Bat terminal on solenoid to I terminal.
Use screwdriver from Bat terminal to S terminal.
Be sure it's out of gear first.
Old 06-08-2011, 09:23 AM
209 209 is offline
Cobra Make, Engine: Superformance 2765 Roush 427(POS) with cruise.
I guess that's assuming your hood isn't locked?? 209
Old 06-08-2011, 09:24 AM
The screwdriver won't reach around from the S to the Bat terminal, so you just go from S to I. Full credit, though. Damn that Chas for sleeping in late -- I just know he couldn't figure it out. He's "electrically" challenged, you know.
Old 06-08-2011, 05:01 PM
DanEC's Avatar
A wire from positive on coil to positive on battery and jump the starter relay with the screwdriver. Don't know how your going to get from the coil to the battery with only 3 inches of wire however??????????
What's the answer?
Old 06-08-2011, 05:05 PM
What's the answer?
392Cobra gave the correct answer. You use the wire to jumper from the battery post on the starter solenoid to the I post which runs to the ballast resistor. You then use the screwdriver to touch between the S and I terminals to crank the starter. The car then starts and runs, but half the electrical system, including signals and lights, will not work. Now, if Chas. would just log in I could ask him how he would enable the rest of the electrical system with a single one-inch wire.
Old 06-08-2011, 05:40 PM
LMH's Avatar
LMH LMH is offline
How did this happen to come up for discussion though? Did you loose your keys?
Alba gu bràth
Old 06-08-2011, 05:56 PM
No, it was much more than that...
Lykins Motorsports, LLC
www.lykinsmotorsports.com
www.customfordcams.com
brent@lykinsmotorsports.com
Old 06-08-2011, 05:58 PM
I thought I did, Larry, but it turned out the key was in a seam in my trouser pocket. Soooo, while I was looking in all the places the key was not, I was also thinking how I would hotwire the car to get home. And then I found the key.
Old 06-09-2011, 06:06 AM
Cobra Make, Engine: ERA #624 (427 S/C), 428 PI
I would wrap the wire around my index finger as a reminder, grab the screwdriver by the shaft, tap it with vigor on top of my head for being so *&^$ to loose my key, and then reach for the Hide-a-Key and go home !
If you want manners, drive something else....
COBRA's are ALL about EXCESS !
Old 06-09-2011, 09:55 AM
rodneym's Avatar
Full Blown Member
Premier Contributor
Chas must be polishing his mags.
rodneym
Old 06-09-2011, 10:08 AM
RodKnock's Avatar
Trouser? When were you born? The 1800's?
Please don't say the "M" word. I might have a seizure.
Old 06-09-2011, 10:27 AM
No, that subject has gone on and on ag nesium. Dang, that was clever.
Old 06-09-2011, 10:54 AM
RodKnock's Avatar
You can regale yourself and your buddies with that one next time you take your ERA to the oyster bar.
Old 06-09-2011, 11:13 AM
I would even buy Chas an oyster. Perhaps he's under the weather, it's rather unusual for him to remain silent, as captious as he is.
Old 06-09-2011, 11:42 AM
rodneym's Avatar
Full Blown Member
Premier Contributor
Trousers? While driving a Cobra?
Patrick, you sir, are a Dandy.
Top of the day to you.
rodneym
Old 06-09-2011, 12:10 PM
Remember when Popeye would say "that's all I can stands; I can't stands no more!" I feel Chas is now reaching for the keyboard with those gnarly, sticky fingers of his....
Old 06-09-2011, 02:48 PM
RodKnock's Avatar
I think he just figures you're nuts and likely has no desire to play into your brain games derived from sheer boredom.
Old 06-09-2011, 02:57 PM
Now I don't believe that for a minute.
