Old 01-25-2012, 10:42 AM
kgs365's Avatar
Default ERA - front battery cut off switch
Hi
I searched first !....how are you folks wiring in a cut off switch on a front mounted battery in a ERA...I just bought one of those "green" knob simple switches and was just going to mount directly to the battery as a simple fix...but wanted to see what other set ups are out there
thanks
Old 01-25-2012, 01:49 PM
Default Behind the Green Knob...
The Green Knob, works like a charm....
Old 01-30-2012, 11:33 AM
CobERA's Avatar
Cobra Make, Engine: ERA #644 428 FE
If you are willing to spend a little money, check out a Battery Brain Gold. I have one on my ERA and you can connect/disconnect the battery with the supplied remote. I have had mine on my car for a few years, with no problems.
Rick
ERA 644
I'm getting old too fast and smart too slow!
Old 01-30-2012, 11:50 AM
Uhhhhh, I don't know.... It looks like something that would have a mind to break down somehow. I like the plain old mechanical green screw knob thingy.
Old 01-30-2012, 04:04 PM
flaflier's Avatar
Cobra Make, Engine: ERA154 427 HR
Um, not sure when I would think " I'm going to disconnect my battery, watch this" and pull out a fob... just wondering... I have the removable key turn thingy in the trunk.
Old 01-30-2012, 06:05 PM
Rick Parker's Avatar
The green knob works quite well just take it with you. Vise grips are the only way to overcome it OR have another Green Knob.
Rick
Old 01-30-2012, 06:20 PM
kgs365's Avatar
the green knob showed up today...will be my first mod!
Old 11-02-2013, 09:14 AM
Revisiting this thread. I have a green knob but it is toward the outside of the car (under the fenderwell) and behind the fresh air hose, so it's hard to reach. I'm considering a similar simple mechanical switch I can mount on a bracket under the hood in a more easily reachable location. Anyone done this? What's the setup/switch?
Old 11-02-2013, 10:41 AM
I don't understand. Does it not look like mine?
Old 11-02-2013, 11:10 AM
mrmustang's Avatar
Gold Star Contributor
Patrick,
From the sound of it, his battery is mounted the reverse of yours. A simple turning on the battery 180 degrees will work to make his access like yours.
Bill S.
Old 11-02-2013, 11:24 AM
Bill is right. Mine has the positive toward the outside of the car, which makes it hard to reach. ERA recommends it's installed this way so the cables can reach. If I turned mine around so the positive terminal is closer, both terminals would be facing the front of the car.
But I just noticed it looks like Patrick installed the switch on the negative terminal. Am I right? This would solve the problem as well.
Old 11-02-2013, 11:26 AM
lamaluv's Avatar
I also use the "removable key turn thingy". It is mounted on a bracket on the dash support tubes. For security purposes remove the key and take it with you or hide it somewhere in the car. For safety purposes you want the turn off within arms reach or where others can get to it easily in an emergency. Like an electrical fire while driving down the road or a stuck throttle. Just two of the times that I have been glad that I had a cut off switch.
Old 11-02-2013, 11:32 AM
Patrick,
Bill S.
Yep. Good thinking.
Yes, on the negative. That is the preferred method for installation.
Old 11-02-2013, 02:02 PM
I'll just install the green switch on the negative. Problem solved. Easy. Thanks!
Old 11-02-2013, 02:06 PM
DanEC's Avatar
Lippy, mine is mounted on the negative terminal also . Not ideal but I've done it this way on my Corvette for years and now the ERA - with no problems.
I prefer the knife blade contact-type switch and use that on my Corvette. I have had green knob switches that sometime make contact and sometimes don't. But not enough room in the ERA to use the knife blade type.
