December 2025
Old 07-13-2012, 07:39 PM
ERA 778's Avatar
Cobra Make, Engine: ERA #778 427SC Keith Craft FE 428 stroker
Default Upgrade for standard ERA electric horns
I've got the standard electric horns provided by ERA. Frankly, I'm not sure they make enough noise to be heard above the engine. Has anyone a suggestion for a more aggressive, high volume horn with out going to a giant air horn like on an 18 wheeler?
Thanks,
Hal
Old 07-13-2012, 08:58 PM
Cobra Make, Engine: ERA 289 FIA #2027, 65' 289" PS wheels
Default the simple way...move the horn...!
ERA 778,
I relocated the drivers side horn to the front of the radiator bulkhead.
This was the result of using one of the horn "threadserts" to mount the bracket for the oil thermostat I added. The wiring harness was just long enough.
Doubt if this will result in Diesel Locomotive type notes...that would be interesting...but it HAS to be louder than hiding the horns behind the radiator shroud bulkhead...!
If you live in the slushy, frozen, salt ridden part of the world...you know, east of LosAngeles...you run the risk of having it plugged with a cinder loaded ice-ball...
Whatever you use just put it in front of the radiator bulkhead, it has to help.
Pete
ERA 289 #2027
Old 07-13-2012, 09:01 PM
SSSammy's Avatar
Default Fiamm
Get a set of aftermarket FIAMM Highway Blasters at PeP Boys or Amazon. $20 and they HONK! Bolt on replacement for stock. Get a High Note and a Low Note, not two of the same thing:
FIAMM 72102 12 V High Note
FIAMM 72012 12 V Low Note
Btw, the stock ERAs have to have correct polarity to beep correctly.
Sam
Old 07-13-2012, 10:32 PM
Dangerous Doug's Avatar
Cobra Make, Engine: ERA 289 FIA #2108
One of my buddies and I were spiritedly returning from lunch, the Cobra fueling ample amounts of testosterone and adrenaline, and he asked, "Does this thing have a horn?"
I replied, "Sure!" and hit my horn button for the Volkswagenesque "beep beep".
He stared silently forward, then turned to me and sternly admonished, "Don't ever do that again!"
Yeah, you've got to ditch those VW horns. I got my Hella dual trumpet horns from summitracing.com. They sound like a "regular car" instead of the VW horns. Much improvement.
Hella 007424801 - Hella Dual Trumpet Horns - Overview - SummitRacing.com
DD
Dangerous Doug
"You're kidding, right?"
Old 07-14-2012, 04:23 AM
Default It's not loud but
ERA 778 Any thought of going with the BEEP-BEEP Roadrunner horn?? That will scare the heck out of the you know what to the guy next to you. I think nascar should also add them to their cars. With all the bad accidents on the super speed ways, maybe this would help keep the cars in the lanes and stop the cutting off of each other. Problem is they don't work in NJ or NY Rick L.
Old 07-14-2012, 12:15 PM
ERA 778's Avatar
Thanks, guys. I just ordered the Hella units. I'll post the results once I have the horns and have them installed!
Rick: I think the Roadrunner idea is great! However, the original horns remind me too much of them already! Maybe if I unhooked one of them the sound would exactly like the RR!
Old 07-15-2012, 05:21 AM
Snakebit's Avatar
Club Cobra Member
Cobra Make, Engine: ERA 289 FIA #2100 Rio Red Wimbledon White Stripes 302 stroked to 331 Webers Richmond Road Race 5 speed
I replaced mine with the Hella Supertones. You can definately hear them.
Snakebit
Old 07-21-2012, 01:44 PM
ERA 778's Avatar
Thought I'd finish this topic. I installed the Hella Trumpets this week. They fit perfectly, no issues; mounting bolts and connectors exactly the same. Soud is MUCH better: louder and more agressive - just what i was looking for at about $30!!!
Thanks everyone.
