30Likes
07-08-2015, 08:26 PM
Originally Posted by prp289
.... Going to powder coat the dash and roll-bar satin black. ....
Phil,
For powder coating I can highly recommend Accessories Plus in Belmont. They did several parts for my Cobra and did an excellent job. As I recall, they have a lot of different levels of finish for black (8 or so), all the way from very flat to very glossy. You might also consider a flat/satin finish on the dash and a more glossy finish the roll bar. Lots of good choices. I too like the F250 tow vehicle, it will make for quite a combo
- Tim
07-08-2015, 09:23 PM
SA
....Also I am looking for a Tailhousing for my Toploader, mine is from a 67 Mustang and the shifter mount is in the wrong area.
Phil,
Regarding shifter location, if your Toploader is from a '67 Mustang, it most likely has the correct 14" length tail housing . Mine has the same length tailhousing but I needed to relocate the Hurst shifter further forward and lower down. All that was required was a new mounting plate/bracket.
Glen
07-21-2015, 08:32 PM
Cobra Make, Engine: ERA FIA 289
She has Paint!!!!
07-22-2015, 04:32 AM
wa
Sensational
07-22-2015, 06:08 AM
Looks great, must be very exciting.
Bill
07-22-2015, 06:20 AM
OR
Pretty
ERA FIA 2088
07-22-2015, 06:45 AM
Very cool, nice choice and it looks great...............
07-22-2015, 03:30 PM
Very nice - major step. Now a little minor assembly and you will be on your way.
07-22-2015, 10:37 PM
Phil,
Looks absolutely fantastic! A lot of hard work to get to this point, you are doing a great job!
- Tim
07-23-2015, 10:06 PM
SA
Looks great Phil! You have me thinking I should be considering a white stripe as well...
Glen
08-23-2015, 03:08 PM
Saw this ERA FIA Cobra at the Norcal Mini Nats. Liked the extra bar around the door..
08-23-2015, 03:12 PM
1 more Pic.
08-23-2015, 07:44 PM
Cobra Make, Engine: Contemporary Classic 289 FIA
Very nice.
08-23-2015, 08:20 PM
Phil,
I was at the Nor Cal mini nats too, and the same ERA caught my eye as well. I briefly talked with the owner and this is the FIA that is on the ERA website. A great example of ERA’s craftsmanship being regularly exercised on the track. I have no doubt that your car will be much the same!
- Tim
08-23-2015, 08:36 PM
SA
Nice car and nice pictures gentlemen. Like the colour.
Glen
10-21-2015, 08:24 PM
Starting to install the panels and some exterior items. Has any one used the Clutch slave cylinder from Modern Driveline. Wonder if it would work? Starting to get going on building and engine. Hope to install motor early next year. Fingers crossed...
10-22-2015, 03:16 AM
OR
I remember those days! Always great to have those pictures to look back at. She's going to be a stunner!
ERA FIA 2088
10-22-2015, 05:19 AM
Looking good. First thing - I don't know anything about the push from the rear type of slave setup. Your fork pivots on the right side of the bellhousing - right? It looks suspiciously to me like you have less mechanical leverage with that type of set up and would need a slave with more than the usual 1 inch +/- stroke. I would think that the pivot should also be shimmed a little forward to move the left side of the fork back towards the slave cylinder a little more so that there is plenty of room for fork travel without hitting the front of the fork opening in the bellhousing.
But - I don't really know anything about this type of set up.
10-26-2015, 06:14 PM
The #142 FIA car, is that Joe R's ex car, from NY/CT? Not only a Very nice build, but exceptionally fast (at least with laid back Joe running it).
10-28-2015, 03:57 PM
DanEC Found out from Brent Lykins from Lykins Motorsport that the pivot on the Fox body 5.0 is on the pass side. Never built one up so I never new that. Used to the 60/70 mustang style... He said the push type was better for that style.
