03-17-2014, 11:13 AM
OH
Cobra Make, Engine: ERA 714
Locking Dash
I have the standard ERA dash with no lock. Has anyone retrofitted a lock on your ERA? If so, where did you get the lock?
Phil
03-17-2014, 12:25 PM
Phil
What are you trying to lock?
03-17-2014, 12:37 PM
He probably means the glove box.
Alba gu brąth
03-17-2014, 12:41 PM
Alba gu brąth
03-17-2014, 12:44 PM
Originally Posted by LMH
You'd have to fab a little brace on the inside, but that would work without much trouble.
03-17-2014, 01:47 PM
OH
Yes, I mean glove box. Price looks steep, but that looks like what I need.
What am I trying to lock? Radar detector, phone, little things I don't want to carry.
Phil
03-17-2014, 02:16 PM
Tx.
Cobra Make, Engine: SPF #1235
Superformance #1235
460/T5
03-17-2014, 02:24 PM
Originally Posted by dont
That one actually might be easier to install.
03-19-2014, 06:47 PM
OH
Ordered and on the way!!!
Phil
06-17-2015, 02:35 AM
locking dash
The glove box lock from A.H. Spares LTD does not fit a Superformance Mark III. The glove box door is too thick for the lock.If anyone is looking for one contact me. 25% off list.
06-17-2015, 06:49 AM
Cobra Make, Engine: Superformance 427SC/Roush 427IR
Phil,
You may have found what you're looking for, and this center console might not work for you as it's designed for Superformance cars. I installed one and use it a lot more than my locking glovebox plus it's a nice arm rest for longer cruises. It does have a lock, so some level of security, although it probably won't stand up to someone who really wants to get in. There are a couple of threads on the Conra Club if you want more information.
Mk III Console
06-17-2015, 04:09 PM
John...My glove box is about 7/8" thick...would your ahspares lock work for me? If so,
I may buy it from you. Sounds like you want about $75. Let me know...Kit
06-18-2015, 06:33 AM
ct
Phil
There is many times I wish mine would lock. Can you post some pics when you are done?
Dave
06-18-2015, 08:50 AM
Locking Dash
The barrel that goes through the dash is a little under 1/2 inch. You would have the same problem I do.
06-18-2015, 08:59 AM
SK
The back side could be counter-bored, but that may be something owners are loathe to do.
Brian
06-18-2015, 02:01 PM
Locking dash
That wont work. The total length of the lock from the flat that sit against the front of the glove box to the latch is 11/16 of an inch.
06-19-2015, 04:05 PM
OH
Here is mine. I used the Seadog lock and works great!
Phil
06-19-2015, 04:07 PM
OH
I had to enlarge the hole, but that was not a big deal. I simply removed the old puller and locking mechanism, was careful with the leather and drilled the whole through the wood and put the lock on. It works great! Let me know if you need more pics.
Phil
06-20-2015, 08:23 PM
ct
Phil
More pics would be great Phil. Maybe with the back side and where it latches. Does the lock actually hold the door closed now or can you retain the dohicky that keeps it closed? How do you open it without the pull?
My pull is located about 1 1/4" from the hard edge. I measured this on the backside of the door. Is this the standard location for this knob?
06-21-2015, 11:24 AM
OH
Pics below. The door itself holds it closed on mine as its a tight fit. I only lock it when I leave something valuable in it. Usually I can grab the edge of the door leather part and it pulls open. I had to slightly bend the locking bar as you can see in the picture to make it work. It was not a big deal. I think the pull knobs are in the same place. Send of pick of the knob location, but I am pretty sure the sea dog lock will work.
