Old 06-16-2014, 09:52 AM
bliss's Avatar
Default Clutch Slave Cylinder leaking
I have ERA 91 (late 80's build) - pictured below is, I believe, the clutch slave cylinder, leaking.
Question: what 'brand', year, etc would this be for a replacement?
Input would be appreciated.
Old 06-16-2014, 10:35 AM
BMW 2002-Bob has the part number-call him.
Chas.
Old 06-16-2014, 11:33 AM
Cobra Make, Engine: ERA 714
I have ERA 714 built in 2005/2006 with the slave cylinder leaking as well. Should I also call Bob? Do you have a part number as well?
Phil
Old 06-16-2014, 12:08 PM
Phil
Always call Bob for ERA related parts. He will supply you or direct you.
Chas.
Old 06-16-2014, 03:31 PM
bliss's Avatar
Normally, posters here post parts numbers, etc., but, yes, Bob also can be contacted - we all know that!
Old 06-16-2014, 03:40 PM
bliss's Avatar
Phil
For my ERA...
Clutch slave cylinder: **
(BMW fits 72-76
2002)
BMW 2152 1104 269
(20.5 mm, .81” ID)
Old 06-16-2014, 04:28 PM
Really? Is that what posters normally do in your vast experience here?? And if you 'all knew' to contact Bob, why did you ask this question here?
Normally OP's say 'Thanks for your help' when someone takes the time to give a correct answer to their problem. A little searching or a call is not too onerous for you is it??
Chas.
Old 06-16-2014, 04:39 PM
DanEC's Avatar
That's one heck of a stout appearing clutch fork return spring you have there.
Old 06-17-2014, 05:01 AM
I simply PM'd Bliss with the link to the latest manuals with all the part numbers.
Old 06-17-2014, 07:17 AM
bliss's Avatar
Yes, really!
Old 06-17-2014, 07:20 AM
bliss's Avatar
I'm not mechanically inclined - one heck of a return spring - is that good or bad?
Old 06-17-2014, 10:15 AM
DanEC's Avatar
Of course it's impossible to tell a springs tension rate from a picture and maybe it's not as stiff as the wire size alone might indicate - at least the coils are certainly close together and relaxed. If the clutch pedal effort is reasonable and it keeps the throwout bearing off of the clutch fingers then it's OK.
