3Likes
06-18-2014, 06:31 PM
OH
Cobra Make, Engine: ERA 714
Bug Screens - Use Them?
Gents,
Do any of you run bug screens over the radiator? If so, did you lose any cooling ability and where did you get one? Bugs are pain to keep cleaning and I am worried I will put a stone through the radiator.
Phil
06-18-2014, 06:37 PM
Originally Posted by Large Arbor
Gents,
Phil
No. Pusher fans work much better -- really.
06-18-2014, 07:13 PM
Use a short bristle 3" wide brush on them-come right off. Don't put a cheesy screen in the nose.
I never took a stone in three decades-still worried?
Chas.
06-18-2014, 09:02 PM
Super Moderator
Yup
Jamo
06-27-2014, 07:12 PM
OH
I like the look of a plain radiator in the front, unless it was a shrouded pusher fan.
Phil
06-28-2014, 04:02 AM
I have a time scrubbing bugs off of the front of my wife's Toyota Highlander. I can't keep up with keeping the thing clean with all the miles she puts on it. I picked up a bottle of Surf City Garage bug remover the other day at Pep Boys and for once, something actually works as well as advertised. After soakiing for about a minute the remains mostly hose right off and what's left just wipes off with a normal swipe of my washing mitt. It and a soft brush will probably make clean up of your radiator fairly easy. Back flushing from the engine side would probably work best.
06-28-2014, 06:10 AM
MN
Cobra Make, Engine: SPF, 395 Stroker
I'm always on the lookout for something that works well on the bugs. I have checked both Pep Boys as well as Surf City Garage. It looks like the product you referred to might be Road Trip Bug & Tar Remover? I can't seem to locate it anywhere though. Is it available as a "standalone" product or only as part of a kit?
06-28-2014, 06:52 AM
MI
Cobra Make, Engine: Shelby, 1964 CSX2367, fully restored, I'm the second owner, SAAC Div 1 Premiere 2003&2012
I've had good results with Griots bug barrier that is sprayed on before a drive. It leaves a slimy coating that keeps most bugs from sticking. Our XK120 is worse than the Cobra for attracting bugs, Lori and I drove it 500 miles two weeks ago and the bug barrier really helped. Even on the radiator core. Dave
Dave Wathen
1964 CSX2367
1938 Jaguar SS100
1953 XK120 roadster
1966 Etype roadster
1971 280SE 3.5 Cabriolet
06-28-2014, 10:06 AM
KS
Cobra Make, Engine: jbl
i've been with and without, tired of the bug thing, especially if you drive at the wrong time or evenings or out in the rural areas. HD has heavy duty screen door stuff to resist cat scratching or assist in vertical height, however you look at it, buy the parts and make your own which is what I did. Did lose a bit of cooling but not enough to put things in danger from driving around on the street.
06-28-2014, 11:13 AM
That's it. I bought it as a stand alone item at Pep Boys. Haven't noticed it anywhere else. I was going to order some Groits before I found it locally. It melts hardened bug mess away although it looks like it also strip most of any wax off of paint also. But I usually apply Eagle wax and dry when washing it and that takes care of that.
06-28-2014, 03:31 PM
MN
I figured it would take the wax off along with the bugs, but that's a small price to pay. Thanks . . .
06-28-2014, 07:54 PM
Cobra Make, Engine: BDR #168 427W 69+K miles and counting
I finally threw away my window screen bug catcher and built a new one. Photo attached. PM for more info if desired.
Bill
"If your work speaks for itself, don't interrupt"
06-29-2014, 06:36 AM
AL
I made a screen out of expanded stainless. 41,000 miles later, lots of rock chips on the paint but no holes in the radiator.
Cooling no problem. I have a 2700 cfm puller fan.
Dwight
06-30-2014, 07:59 AM
OH
Dwight,
What brand is your fan? Mine is only pulling about 1900 cfm and needs a little help.
Phil
07-01-2014, 10:23 AM
Well, darn it - I was at Pep Boys yesterday and they no longer have the Surf City Garage bug and tar remover. I must have bought mine just before they stopped stocking it. I guess I will give Groits product a try next.
07-01-2014, 11:06 AM
The bugs are an irritation. The stones are a potential hole in your radiator and a tow home — with some luck no motor damage from overheating but the cost to repair / replace the radiator.
This is a piece the World of Outlaws cars use to protect their radiators from on track flying debris. It is a 7/16 honeycomb rigid nomex matrix that does not restrict the airflow to the radiator and does protect it from flying debris that can damage the core.
click here => Radiator Protector It is available in several sizes and trims easily. It also washes easily.
Ed
07-02-2014, 07:05 AM
AL
fan
Phil I don't remember. I bought it from a ebay store that sold NASCAR stuff several years ago.
Do a search for the size fan you have with the highest CFM available. Summit, Jegs, Speedway and Ebay
Dwight
just did a Summit 16" fan search and came up with a lot of fans from 2500 -3000 cfm.
http://www.summitracing.com/search?S...rd=16%22%20fan
Reason: add comment
07-02-2014, 09:06 AM
Dwight,
Phil
Phil,
Didn't mean to ignore your post — got distracted and old brain cells dedicated to memory failed me.
There is a relatively low cost fan alternative that is pretty nice. It involves using a fan out of a Lincoln Mk VIII. Early ones were supposed to be 4500 cfm and the last two years of production produced 5000 cfm versions. They can be sourced from salvage yards for ~$35.
After the fan you definitely want to use a fan controller. They are not only high flow fans they are high starting amperage draw. Cold starting the fan can surge over 70/80 amps and damage your electrical system and/or alternator. There is a company called the Hollister Road Company (<= clickable) that makes fan controllers specifically for this fan. The offer two controllers one rated at 85 A and the other rated at 125 A. The 85 will typically work fine the 125 offers a little more head room for $20 more.
Both controllers will give the fan a soft start and then seamlessly vary the fan speed up and down as engine temperature goes up and down. At highway speeds, when there is adequate air flow across the radiator to cool the engine they will shut down the fan. As engine temp goes down so does fan speed. When you shut off the car they will run the fan for approximately a minute after the engine stops.
Way cool controller and the only one like it I could find when I was hunting for mine. BTW when the MK VIII fan goes up to top speed you need to keep women, children and small dogs away from the front of the car.
Ed
Reason: Spelling & Grammar
08-08-2015, 07:34 PM
Could you send me more info on how you apply your protector..pics, and whatever I would need to do the same as your radiator protector?
Willie
Lakewood, CO
08-08-2015, 09:26 PM
Phil, I'm using the same nomex honey comb from Speedway that Ed referred to. Plenty cheap, easy to trim with everyday scissors, almost bullet proof. I used some industrial strength Velcro to install thinking that if I lost some cooling capacity, I could easily remove it. I do run at an additional 5° in our Arizona warmth, but that's livable. Its not as "pretty" as a nice aluminum radiator, but is barely noticeable and I can easily put up with the appearance while greatly reducing my chances of getting stuck out in the boonies with a blown radiator. Just my 2¢ worth.
Karlos
