Old 08-30-2014, 07:16 AM
Cobra Make, Engine: ERA 714
Default Stub Axle Bolt Torque
I am looking to set the torque on the stub axle bolts that hold it in. Anyone know?
Phil
Old 08-30-2014, 10:28 AM
I'm not sure what you're talking about, but there is an excerpt of the Jag service manual covering the differential in the Owner's section of the ERA site.
Old 09-02-2014, 04:41 AM
joyridin''s Avatar
Assuming you are tightening the bolts that hold the stub axle housings to the main housing, the torque on those is 55 lbs/ft. That is for an early style Jag rear. That number may change with the later styles.
Old 09-02-2014, 09:20 AM
CHANMADD's Avatar
I think he's talking about the front......the stub axle has a huge nut holding it to the spindle....I dont remember how tight it is ...I do know I used a nylock nut though.....I wouldn't go much more than 100 lb/ft
Old 09-02-2014, 10:26 AM
55 lbs is what I was looking for and set them pretty close to that. Thanks.
Phil
Old 09-02-2014, 10:29 AM
CHANMADD's Avatar
That sounds more like it......I stripped one once ......
Display Modes
