Old 02-16-2015, 09:04 AM
DanEC's Avatar
Default Turn signals blowing fuse #4 - ERA 782
Thought I should start a new thread on this subject since this problem may not be self-induced and might be of help to someone some day.
To re-cap - blowing the #4 fuse when turn signals are used which also powers off the voltage regulator - and charging. The fast blow fuses to the rear are not affected. The other fuses linked to #4 don't appear affected.
Returned from some more testing - pulled the turn signal leads to the front turn signals and still blew the fuse with a left turn signal (key on but parking lights off)
I reconnected the wires, replaced the fuse and tried a right turn signal. They worked OK and fuse did not blow. Tried left again and as soon as I heard the flasher click the fuse blew.
Pulled the bracket for the flasher and trailer relay down and released the wire harnesss to look everything over. Can't see any obvious sign of pinching, bare connectors or anything.
Probably not the flasher as it doesn't have Lt/Rt circuits. Kind of sounds like it's poining to the turn signal itself?
Suggestions?
thanks
ERA 782 Running
Old 02-16-2015, 09:36 AM
DanEC's Avatar
Disconnected the trun signal power lead to front PL and the yellow lead from the turn signal switch and tested for continuity between both ends - tested OK for continuity. Tested both ends to ground and meter was silent.
Assuming from this there isn't a short in the run to the front bulb.
Edit: OK, think I made some progress. The only other power into the turn signal switch is from the headlight dimmer relay. I disconnected the Tan/White stripe wire from the headlight dimmer relay from the turn signal switch and the turn signals work OK. So, I assume that might indicate a bad headlight flasher relay? Or possibly still a faulty turn signal switch? Any idea how to figure out which one?
ERA 782 Running
Old 02-16-2015, 11:44 AM
Do your headlights work normally and flash on/off with the little button on the turn signal wand?
Old 02-16-2015, 11:56 AM
DanEC's Avatar
Just tried them and they work OK.
ERA 782 Running
Old 02-16-2015, 11:51 AM
DanEC's Avatar
Noticed the alert on ERA's Owners Private Downloads page about some bad headlight dimmer relays getting out. I don't seem to be having the exact issues mentioned in the alert but I haven't used my headlights much. I will turn the HL on and run through a few dimmer/high beam signals and see if anything shows up.
Also found the test procedure for the turn signal switch but as long as the HL dimmer lead to the switch is disconnected it works OK. I think that probably points to the dimmer power shorting to the left turn signal lead - maybe?
Apparently power is flowing from the HL dimmer relay to the dimmer switch or it wouldn't be shorting the turn signal. I guess that would be the main test that it's working. However, should it be sending power to the switch if the headlihghts are off?
ERA 782 Running
I guess you don't want to just pull your turn signal off the steering column and test it off the column, do you?
Old 02-16-2015, 12:08 PM
DanEC's Avatar
I think first I'm going to disconnect the wire from the dimmer relay and run the turn signals in both directions and see if I pick up some voltage on it when I turn the left signal on. I'll also check if the other side feeds power through the relay to the switch even when the HLs are off. At leas then I will pretty much understand how everything works.
Probably at that point I'm going to pull the wheel and the switch out to test.
Stay tuned.
ERA 782 Running
Old 02-16-2015, 12:19 PM
DanEC's Avatar
Surprisingly with the tan wire from the dimmer relay disconnected - I don't pick up any significant voltage from the switch side when running the left turn signal. I thought sure I would pick up shorted voltage through it. Nothing on the relay side either.
And it is 0-volts when HLs are off.
ERA 782 Running
Old 02-16-2015, 11:43 AM
The headlight dimmer relay is only connected to the headlight circuit. Nothing there is connected to the signals. That would indicate something really weird happening within the signal wand. Considering the headlight flasher switch wiring is completely independent of the signal circuits (theoretically), the likeliest thing is a pinched wire. Did I ever send you a new wire module from the under-dash module to the main harness?
Old 02-17-2015, 02:29 PM
Cobra Make, Engine: ERA 714
Dan,
You made me nervous so I went out and checked my LED turn signals and they worked. It could be something in the flasher itself.
Phil
Old 02-17-2015, 04:16 PM
DanEC's Avatar
Hi Phil - I don't have the LEDs in - couldn't get them to work for whatever reason. It appears my short was in the turnsignal/flasher unit. I fastened the trailer relay bracket back up under the dash today and tied up all the wiring looms again and everything is still working properly. For now I stuck a few 20 AGC fuses in the glove box and will see what happens. My car is pretty simple with points ignition so even if I blow the no. 4 fuse and knock out the charging system, I can probably drive for an hour or more just on the battery in daylight.
ERA 782 Running
Old 02-17-2015, 04:17 PM
mrmustang's Avatar
Gold Star Contributor
Dan,
I had the issue with ERA234 when I first bought it, drove me absolutely crazy. Went through all of the wiring looking for loose connections or breaks/pinches with no luck. Replaced the fuse holders with the later stainless units, still no luck, changed out the bulbs and cleaned all connections, no luck. Ended up being the turn signal switch, replaced that and went 6+ months without another problem.
Bill S.
Old 02-17-2015, 04:20 PM
DanEC's Avatar
Bill - I think that is my issue too. I'm hoping for the best but if and when it shorts out again I'll just replace it.
ERA 782 Running
Old 02-17-2015, 04:38 PM
mrmustang's Avatar
My advice is to order one and have it on the shelf for when you are ready to replace it.
Bill S.
Old 02-18-2015, 07:15 AM
Dwight's Avatar
Smile
I've never worked on a ERA
what turn signal switch do they use?
Some of the Cobras I've worked on use a MG, others a VW and one a Ford Fairmont.
Dwight
Old 02-18-2015, 11:14 AM
Dwight
It is a VW Switch, part #141 953 517F that looks like this:
Old 04-05-2015, 09:47 AM
Jerry Clayton's Avatar
Once worked on somebodies car( don't remember what brand--was a cobra tho) and one of the rear tail /brake lites was wired wrong and grd wire was wrong---------
Does it blow when you have brakes on with turn signal??
Old 04-05-2015, 02:08 PM
or you could check the plug, bulb and wiring of the left rear light------grounds are different issue in fiberglass vehicles( and boats) and a socket with two hot wires and one grong with a blub with two elements----------
Old 04-05-2015, 03:02 PM
DanEC's Avatar
Hey Bob - if you are out there - just re-read this in your post back on page 1.
"Did I ever send you a new wire module from the under-dash module to the main harness?"
Is there something I need to replace?
Jerry - I did a lot of trouble-shooting back on posts 1 - 10. I stood outside the car and replaced 3 fuses in a row - each of which blew as soon as I hit the left turn signal. I wasn't even inside the car so stepping on the brake didn't have anything to do with the problem. I isolated it down to the turn signal or dimmer relay and since it blew fuses with headlights off - that seemed to point to the turn signal switch itself. And then it cured itself until a drive I took the other day.
Patrick - possibly a good point. I doubt ERA is spending $250 for OEM switches which means this one was undoubtedly a repro.
ERA 782 Running
Old 04-06-2015, 07:35 AM
DanEC's Avatar
Jerry - the brake and turn signals at the rear are operated by a trailer relay that is protected with 2A quick blow fuses. So far I have never blown them so I'm pretty sure if there was some sort of short at the rear lights it would blow those 2A fuses before it had a chance to blow the 20A fuse at the firewall. I did try removing the front bulbs when this first happened and was repeatedly blowing fuses. Didn't make any difference.
I spent a lot of time trying to make some LEDs work in the rear of the car. I checked and rechecked grounds and all circuits before I discovered it was the led bulbs themselves. So I went back to 2357 filament bulbs. A long story.
Also, it's a very intermittent issue - it's happened once in the last 3 drives I've taken. Works fine at the moment - can't re-create it.
ERA 782 Running
