November 2025
9 10 11 12 13 14 15
16 17 18 19 20 21 22
23 24 25 26 27 28 29
Like Tree7Likes
Old 10-03-2015, 07:23 AM
Mongoose930's Avatar
Cobra Make, Engine: Hi-Tech
On my first Contemporary Cobra with a very streetable 428, I had a TKO 3550 with .68 5th gear and a 3.54 diff. I would absolutely not do this combination again as the car just lugged in 5th gear. I have a 482 in my Hi-Tech and went with the TKO600 with the .82 5th gear ratio. I haven't driven it yet so I can't tell how that combination would work but I drove with the .68 for 2 years and would not do that again. Sounds like a great project - you need to share pictures as soon as possible.
Old 10-03-2015, 08:43 AM
davids2toys's Avatar
Cobra Make, Engine: ERA, 428, 4 speed Toploader, Jag rear, Red with White stripes
Yes, definitely sounds like a nice car. Along with the others, I would re-think the 5th gear choice. I presently have a 3:31 gear and a top-loader 4 speed. My plan is to sell the Top-loader and shifter and get the TKO 600 with the .82 5th gear.
I have a 05 Mustang with the .64 5th gear and 3:55 gears and unless I am doing 80 or better, it is a dog in 5th. Granted, the mustang engine is not a 482 with gobs of Torque to maybe make up for the low RPMs of cruising in 5th with the .64 OD.
ERA#698 428, 4 speed Toploader, 3:31 Jag rear
Old 10-03-2015, 10:53 AM
Dangerous Doug's Avatar
Cobra Make, Engine: ERA 289 FIA #2108
I have the 3.54 ratio with a TKO-600/0.82 in my ERA 289 FIA. I've very happy with this combination, and picked it after studying the TKO-600 0.64/0.82 threads here on CC (nearly a decade ago...).
I'm sure Bob at ERA could offer some sage advice here.
DD
Dangerous Doug
"You're kidding, right?"
Old 10-03-2015, 08:58 AM
I ordered the ERA design rear suspension and a TKO 600 transmission from ERA. Peter and I haven't talked about gear ratios yet, so this discussion will be helpful to me.
Old 10-25-2015, 12:43 PM
Cobra Make, Engine: ERA #773, 482 stroker, cross ram stack injection
I have a 3.54 differential and a TKO with 0.82 5th gear. If you are running a big cam you gotta keep the rpm's up. Even with this set up, anything below 2,200 rpm goes to a down shift.
Drink no wine before its time
Old 10-03-2015, 11:03 AM
*13*'s Avatar
I'm running 3.54 with top loader (wide) behind a small block in the 300-350 hp range. It seems good but might be a little nicer with a lower gear out on the highway. Around town I have no complaints.
ERA FIA 2088
Old 10-03-2015, 01:47 PM
You'll be happy with the ERA and with Brent. He is a solid guy. Check out my build thread Lippy's ERA #797 build log and PM me if you want any more color on options, etc. My car has been on the road for about 18 months and I've put on 3,500 miles. Of course there are a few things to figure out but generally it's been rock solid. FYI I have a 3.54/0.82 combo, but my engine is a solid roller/high revver. 640 HP/589 Tq.
Old 10-03-2015, 03:58 PM
RockBit's Avatar
Cobra Make, Engine: ERA #812 427/482 FE
Your car is gorgeous. Surprisingly, it is about the same color mine will be, very dark blue. I saw a Superformance this morning the same color. I will be getting silver stripes, though.
One difference is I went with a hydraulic roller cam. Lots of similarities between yours and mine, though!
Chris
Old 10-03-2015, 03:29 PM
Cobra Make, Engine: ERA 3012
I've got an order in on a slabside with a delivery ETA of May. Still have not decided on all the options I'm going with, but it'll have a 393w with a 3.31/.82 combo.
CSX 2568 is my inspiration for this build.
Old 10-03-2015, 03:33 PM
*13*'s Avatar
That's a lotta motor for a skinny tire car!
ERA FIA 2088
Old 10-03-2015, 03:51 PM
I've actually been stressing out a bit over just that lately. I originally planned on building an FIA when I was getting the motor together, but after seeing the slabside it just really called out to me. People think I am crazy when mulling ways to reduce HP -- we'll just wait and see I guess. Hopefully I am not blowing spokes out all over the place
Originally Posted by RockBit View Post
When I visited ERA in August they were getting ready to start another chassis. I think it was yours. I hope it is a great car for you.
Thank you. I bet it was as that was around the time they sent me the first pictures.
Old 10-03-2015, 09:19 PM
If you are going slab side, why not build a stroked 302 based block? That way it would look correct in your chassis. You can still get big inches out of a 302 block and maybe save some money.
Tom
Old 10-03-2015, 03:35 PM
RockBit's Avatar
Chris
Old 10-03-2015, 03:39 PM
RockBit's Avatar
I poured over gear ratio threads before making my choices. It seemed like cars that would be run on the track favored the .82 OD, while cars for the street and highway favored the .64 OD. I think it comes down to how the car will be used, and the engine and cam.
I appreciate everyone's thoughts. The expertise on this forum is amazing.
Chris
Old 10-03-2015, 03:48 PM
Absolutely right. I've written time and time again that my TKO's first four gears will take me to (with a solid lifter cam, mind you) over 130MPH. My .64 fifth gear is used for one purpose, and one purpose only. And that is calm, relaxed, easy highway cruising, generally in the low seventies. There's a sweet spot where the engine is actually relatively quiet and you can chat with your passenger, or just hear yourself think. It is one of my absolute favorite things to do with the car. I'd still point you at the 3.54 though.
Old 10-03-2015, 04:04 PM
RockBit's Avatar
I agree with you. My thoughts are gears 1 through 4 are for in town. OD is for the highway. I think either the 3.54 or 3.31 will be ok, but the local guy mentoring me knows a lot. (You guys know him). If it doesn't work out, I'll change it.
Chris
Old 10-03-2015, 04:34 PM
You're going to be just fine with either. Who knows, since I've never had a 3.31 in my car, maybe he's right.
Old 10-10-2015, 07:31 PM
jetblue69's Avatar
Cobra Make, Engine: ERA #816, 427 Side Oiler
Seems like it's been a long time since we have had anyone waiting for delivery or working on assembly of a new ERA project. I think prp289 (Phil) is in some stage of finishing his up but it seems like it's been awhile since he has checked in too.
Anyone lurking out there waiting on their car or working on assembling one?
Just put a deposit on mine Tuesday. Trying not to think about it too much otherwise the second hand only ticks once a day...
cobra likes this.
Old 10-10-2015, 08:14 PM
*13*'s Avatar
There are benefits to the wait time. I came across some extra funds during the time of my wait which allowed some upgrades. I think the most unbearable wait is the time in which it's being transferred from ERA to you.
ERA FIA 2088
Old 10-10-2015, 08:19 PM
DanEC's Avatar
Congratulations - can you fill us in on some of the details so far?
ERA 782 Running
Display Modes
