Old 07-13-2016, 11:22 AM
Default ERA 427 leather spats
I have these spats I got with another car a long time ago (never installed), but they came with no instructions and I'm not certain they are the same ones that ERA sells. I have the ERA instructions I found online, but when test fitting these, they don't seem to fit the contours of 488 well. Perhaps there was a running change, or these are some sort of generic spat? Any insight from these photos?
Thanks
Old 07-13-2016, 11:29 AM
Cobra Make, Engine: ERA 427 S/C, Ford 427 Side-oiler 2x4 bbl
Thanks
Hey Troy,
Did you call ERA and see what they can tell you?
I've had real good success getting info straight from them.
Phill
Old 07-13-2016, 11:32 AM
Phil,
That is my hope posting this in the ERA forum with PHOTOS that they can't see on the phone (:
Hope all is well with you.
Troy
Old 07-13-2016, 11:44 AM
Phil,
Troy
Just finished my 45th (9 weeks) of radiation treatments.
I have a follow-up appointment in one month and hope to know more (success/failure) then.
Having a blast with #446,
Phill
Old 07-13-2016, 01:33 PM
Cobra Make, Engine: ERA #448, 1964-427
Greetings Phill,
Wishing the best for your recovery. I am also having a Blast with my #448. Your car and mind were probably roommates !!!!!
Old 07-13-2016, 02:55 PM
Phil - hang in there. You are a tough dude, and I pray you get through all this. I hope the Cobra provides you with much needed driving therapy when you are feeling like crap.
Old 07-13-2016, 04:35 PM
DanEC's Avatar
Hi Troy - those appear to be ERAs. They do seem to fit a little off. I don't have a good close up of mine but you can see how they fit here.
I take it you have not installed the Velcro strips in the wheel wells and the snap to the bottom floor pan yet to secure the lower flap?
Seems I remember that ERA had a running change in the rear flare and it may be they had to re-shape the spats a little as a result.
ERA 782 Running
Old 07-13-2016, 06:39 PM
Dan, the leather tab area for the top fastener appears much narrower on my set, resulting in a large gap as it approaches the door. Yours appear to fit much better, but I have NOT tried installing any of the fasteners yet or velcro. Just a test fit, and it seems off to me.
Old 07-14-2016, 05:14 AM
DanEC's Avatar
I can take some close up pictures of mine this evening and post. You may need to talk to Jack at ERA and see if he knows if there was a change in the spats over the years.
ERA 782 Running
Old 07-14-2016, 06:50 AM
davids2toys's Avatar
Cobra Make, Engine: ERA, 428, 4 speed Toploader, Jag rear, Red with White stripes
Her is a couple of shots of mine. Hope this helps
ERA#698 428, 4 speed Toploader, 3:31 Jag rear
Old 07-14-2016, 07:56 AM
Tim7139's Avatar
Cobra Make, Engine: Superformance #2660, FE-406
Not for nothing but why would you not simply go with a clear film solution ? A far better result IMHO.
The older I get, the faster I was.
Old 07-14-2016, 08:49 AM
I'm not completely sure what, but leather spats just calls to mind something other than a Cobra. I kind of agree with Tim.
Old 07-14-2016, 09:06 AM
There is something a bit more authentic and period correct to the look of the leather spats that seems to "fit" with certain cars. A dark colored street 427 comes to mind (: It's all for fun, right?
Old 07-14-2016, 09:07 AM
That would be great - thanks. When you use your top, do you simply leave the top snap unused where the spat resides? Do the underside details match what is shown in my photo?
Old 07-14-2016, 09:09 AM
No, something like this tends to come to mind...
Old 07-14-2016, 10:29 AM
DanEC's Avatar
Yes, on my black car they are really not very noticeable.
I had my top on two winters - the first one I removed them. I do have the lower portion of the rear flare covered with clear film. The second winter I left them on and just let the top run across the spat extension and of course I couldn't fasten the top to that lift-a-dot. The one closest to the door typically secured the top OK. A couple times I kind of bumped the edge of the top getting in or out and it came unsnapped - but that might happen either way.
ERA 782 Running
Old 07-14-2016, 04:38 PM
DanEC's Avatar
Hey Troy - it might be easier if you PM'd me your email and I can email you the photos. Seems I have over-taxed my Photobucket account and I'm not about to pay the blood suckers $30 bucks a year for 10 times the storage it took me 13 years to use up.
My Spats are quite a bit thicker in width up near the top of the fender than yours. Must be some sort of change made by ERA.
Here are some photos - opened a new storage place.
https://www.flickr.com/photos/142308.../shares/Tc4ixT
ERA 782 Running
Old 07-14-2016, 06:40 PM
Dan,
That's exactly what I needed to see. I'm sure the ones you have would fit my car MUCH better, so I'm going to abandon trying to use the ones I have. I doubt they are from ERA. They don't look much like yours at all - other than the installation and fitting procedure.
Thanks!
Troy
Old 07-15-2016, 03:18 AM
DanEC's Avatar
Possibly not ERA - I forgot to mention that on the back side of mine I added strips of self adhesive backed felt on the edges and to pad the area around the lift-a-dot snap to protect the paint. That gives the back side a little different appearance from how they looked as received from ERA.
ERA 782 Running
Old 07-15-2016, 12:35 PM
1985 CCX's Avatar
Troy
Had them on my old CCX.
They are easy to install and add to the look.
