9Likes
07-23-2018, 02:54 PM
Cobra Make, Engine: Everett Morrison
Originally Posted by MOTORHEAD
Rawkrawler: That's the rocker set I have, any idea who makes those ?
Ted
What a great question, I sold it in 2012. With the 17G folder on this Cobra containing 1,023 pictures I would have certainly thought I'd be able to find the part I used. Wish I knew. I remember it being a small company with a very limited number of SKU's. The picture I posted resembled it, pretty sure it's not the identical piece.
Mike D
Tampa Fl
07-23-2018, 03:43 PM
Cobra Make, Engine: ERA #418, 428FE
Spoke with Jim Coleman today, he said to take off the valve covers and then call him back. Everything you guys told me to do  So perhaps this weekend I’ll do that.
1995 ERA #418
07-23-2018, 04:12 PM
… and take pics and post them here.
07-24-2018, 03:51 AM
Cobra Make, Engine: ERA#375, FE 428, 1966 block, built by Jim Coleman Racing Engines, Stratford, CT
Let me know if you need a hand with anything. Art
ERA 375 - former Clubcobra ID REDSC400
TESLA P90D is my daily driver
07-24-2018, 08:41 AM
I've got to think having the end supports, even though they are not bolted down, has got to be a big improvement over not having them.
Karlos
07-24-2018, 04:00 PM
Now there's what I wanted to know.
How does that offer any more structure rigidity?
07-24-2018, 05:29 PM
Cobra Make, Engine: Superformance, 427SO
On my T&D system, the outer rocker arm and the one next to it is supported by a single integral unit. Better explained with a picture.
Ted
07-24-2018, 05:41 PM
This was a pretty good thread on end stands and several posts address that very issue: https://www.fordfe.com/end-stand-sup...ot-t90234.html
07-24-2018, 10:07 PM
Seems like it kind of converts the single shear mounting of the end into a double shear version. Which is always beneficial, because it takes the flexing of the end away.
07-24-2018, 10:57 PM
The end stands incorporate the end plate, so tying the assembly together as one.
07-25-2018, 07:02 AM
KY
End stands ARE bolted down.
They support the cantilevered part of the shaft.
07-28-2018, 09:18 AM
Passenger side, so far nothing out of ordinary
1995 ERA #418
07-28-2018, 09:39 AM
Driver side, culprit
1995 ERA #418
07-28-2018, 09:53 AM
Yep, that'll do it. BTW, what's that crud on #6 rocker? Looks crystalized, but mayber its just the photo?
Karlos
07-28-2018, 10:00 AM
It feels like dry oil if that makes sense. I'd really now like to replace the valve train with a nice new roller set-up or something more modern, like Ted's.
1995 ERA #418
07-28-2018, 10:03 AM
Yep, that's the problem.  But that's really not too serious... and you needed a new rocker system anyway.
08-04-2018, 06:27 AM
It’s going to Jim Coleman on Monday, likely a Harland Sharp roller setup.
1995 ERA #418
08-04-2018, 09:40 PM
all of those pushrods look mighty close to the intake, i would check each one for rub marks, you may need some intake massaging....an orifice enlarging mission
Fred B
08-05-2018, 08:22 AM
The very few of these system I saw had shims on the shafts to move the pushrods slightly to center them on the valves and in the holes.
As mentioned, keep a very close eye on those pushrods when mounting the new system.
Somebody working more on FEs can add more to this, which I am keen to learn about.
08-07-2018, 12:19 AM
ct
I'm with you on that one!!!
