Like Tree4Likes
  • 1 Post By strictlypersonl
  • 3 Post By Cobra #3170
Old 08-19-2019, 08:27 PM
Default Scaling the car to 50/50
I am wondering if i should scale have my car scaled to all 4 corner and front and rear.. I was watching a show and they scaled their project.
Old 08-20-2019, 06:24 AM
If the car sits level from side to side and the handling balance is also equal, scaling is mostly an unnecessary luxury. Just make sure that your tire pressures are symmetric first.
vntgspd likes this.
Old 08-20-2019, 06:36 AM
Thank you Bob
Old 08-20-2019, 09:57 PM
bobcowan's Avatar
Do a search on cross weights. On a street car, they don't need to exact. But getting them pretty close will help the car handle and brake better.
You can't significantly change front to rear balance or left to right balance without physically moving weight around.
But you can significantly alter cross weights with suspension adjustments.
.boB "Iron Man"
NASA Rocky Mountain TTU #42
www.RacingtheExocet.com
Old 08-21-2019, 09:28 PM
I have found over the years of making mistakes and then trying to correct them that:
In a non ABS car like a Cobra you are better off going for equal front tire weight than equal cross weight. If I set up for equal cross weight the front tires will have unequal weights and the light one locks up under heavy braking. Since 70% or so of braking force is generated by the front tires I always found it better to equalize front tire weights and accept what I got for unequal rear weight. We have tried it both ways and equal front tire weights were always slightly faster. The best of all worlds is equal side to side corner weights but if you can't get there, equal front weights give you more consistency in braking.
scottj, DanEC and vntgspd like this.
Old 08-22-2019, 09:04 AM
Cobra Make, Engine: ERA FIA 2158, ERA 427SC 649 sold
Don't forget to compensate for the weight of the driver.
Old 08-22-2019, 09:32 AM
Seagull81's Avatar
Cobra Make, Engine: FFR3542K, 347 C. I., EFI, T-5, Miata Front Sway Bar, 3 Link, Red with White Stripes
Make sure you have the ride height set before you corner weight your car. If you were closer you could do it at my shop.
Steve
Texas Cobra Club-Austin
July 2009 FFCars Picture of the Month
FFR3542K, 347, Holley Sniper EFI, T-5, 4 Wheel Discs, 3-Link, Miata Front Sway Bar, Red with White Stripes
Old 08-22-2019, 09:46 AM
Corner weight the car. It can make a big difference on the street. Just do it. If you have any doubts, check out this lengthy thread, especially the very last post, which says it all. Best way to adjust rear coil overs for proper height on my SPF
Old 08-23-2019, 06:26 PM
ERA 626's Avatar
Patrick seems to be impressed with himself...
Old 08-24-2019, 12:15 AM
Thanks again.
Old 08-24-2019, 05:14 AM
DanEC's Avatar
The voice of experience. This makes good sense.
ERA 782 Running
