| S |
1 |
5 |
| 7 |
8 |
12 |
| 14 |
15 |
19 |
| 21 |
22 |
26 |
| 28 |
29 |
30 |
2Likes
Post By my427cobra
Post By Blackbart
04-28-2021, 06:35 AM
NY
Cobra Make, Engine: ERA #804
Wipers do not work ERA 804
My wipers have stopped working on ERA #804. I disconnected the terminal block at the motor and connected the motor to a 12V source battery. The motor works. I've checked for power at the terminal end. With the ignition on and the wiper switch in any of the positions, I do not get any power to the terminal block. The fuses are fine and I have been unable to get the switch out of the dash. (what tool works to remove a very tight trim ring?) The connections to the switch are all tight. I've tried to follow Bob's wiper motor check/trouble shooting guide but am still at a loss as to why no power at the motor.
04-28-2021, 08:56 AM
You have to make your own hand tool that goes over and around the switch itself and then the prongs on your tool fit in the little slots so you can get some good torque on the twist. The right homemade tool really makes it easy though. I whipped one up with just stuff I found in the garage. Then, just trace the circuit up to and including the little circuit board that's mounted up on the left hand side under the dash above the steering column. You can't miss it -- it looks like something that came out of a Heath kit from 40 years ago.  If you're lucky, it's just a bad pin in one of the connector plugs and wiggling the wires makes it work, but anyway, that's how you do it.
04-28-2021, 09:55 AM
Club Cobra Member
ca
Cobra Make, Engine: NAF 427
Moss Motors sells the tool (#37-2500) to tighten/remove the bezel on Lucas toggle switches.
Probably on e-bay too.
Greg
04-28-2021, 10:11 AM
PA
Cobra Make, Engine: ERA #795 427 S/C completed Jan. '14 - '68 FE 427 side oiler
If you don't want to make your own bezel tool or it's so tight you really need something machined, Google "Lucas switch bevel tool" and you'll see there are tools available to remove the bezel. Moss Motors seems to have the one you'd need.
"Anyone who drives faster than you is a maniac and anyone who drives slower than you is an idiot" - George Carlin
04-28-2021, 11:05 AM
The little tool I made also works on the ignition switch bezel which, if you ever have to change out your ignition switch, presents with the same PITA problem. Doug and the boys must have torqued it down to like 200 ft/lbs when they put it in.
04-28-2021, 01:20 PM
NV
Neutral
Is there a relay in the circuit??? Most things that have high current or a motor and a switch usually switch the relay leg instead of the item itself.
Tony
CSX4005LA
04-28-2021, 02:31 PM
Nope, no relay. The "parking function" of the original Lucas switch is replicated by a small circuit board. I don't think those burn out too often, but there's really not much to the circuit other than wires, connectors, the switch, the motor, and the circuit board.
04-29-2021, 08:43 AM
Cobra Make, Engine: ERA 427
I would place my money on one of the connector plugs. I had several problems on #821 with the pins not making contact with its mating pin on the other plug.
BD
04-29-2021, 10:31 AM
NY
Thanks to all who replied to my post. A bezel tool was fabricated but ultimately not needed. The problem turned out to be exactly what was suggested, a loose pin connection under the dash. All is good again in upstate New York, well, except for the weather.
04-29-2021, 11:16 AM
Dang, I was going to have you pull the steering column and dash out next to hand splice each and every connector.
04-29-2021, 12:34 PM
NY
That may have been easier Patrick. I'm 6'3" and I am still feeling the pain from the contortions I had to make to see up under the dash and then reach the correct wires. Had it not been for my wife's suggestion to use her make up mirror to "look up there" I may have resorted to taking the car to my local shop. At least now that the wipers work I can rest assured I will see NO RAIN for the rest of my life.
04-29-2021, 01:04 PM
NV
Thanks for following up with the resolution! So many people ask questions and pick the collective brains of the community and never report back on what actually fixed the problem!
Tony
CSX4005LA
