Old 07-03-2022, 09:17 AM
Cobra Make, Engine: ERA 427 FE Shelby aluminum block, dual quads on Dove high rise, 5speed Tremec
Default Coyote engine in an ERA
Has anyone put a Ford Coyote engine in an ERA? Where did you get the motor mounts, who did the work, and what challenges did you face, assuming someone has done this. Thank you.
Old 07-03-2022, 09:24 AM
mrmustang's Avatar
Gold Star Contributor
To the best of my knowledge, it's not as simple a bolt in affair, at least it was not for the 4.6L DOHC that they put in a FIA (2031) many years ago. I was also told back then, while 2031 was under my ownership, that they would most likely never offer such a conversion again. I suspect that you'll need to find someone who can custom fabricate the motor mounts, as well as the modifications you'll need to make to the existing footboxes.
Bill S.
Old 07-04-2022, 07:13 PM
Anything can be done but I believe you are going to have to do some severe cutting into the fiberglass footwells to get that behemoth to fit. My guess would be all the fabrication to make it fit would have to be sourced on your end, I doubt ERA would be interested in trying to make the coyote fit.
Authenticity it sorta the staple of ERA and putting a coyote in their car would be a deviation from that. I think Backdraft and FFR are better candidates for that engine.
Only way to know is to talk to Peter though.
Old 07-05-2022, 04:17 AM
DanEC's Avatar
A few ERAs have been built with 427 SOHC motors which I would think are just as physically large as the Coyote motor but there may be some issues with the Coyote architecture that make it more complicated - oil pan configuration, filter mounting, height, etc.
ERA 782 Running
Old 07-06-2022, 10:41 AM
We could justify installing the 427 SOHC engine. At least a few were put in the original cars by Shel hisself.
Old 07-06-2022, 12:27 PM
Buzz's Avatar
Did Ol' Shel ever install dual roll bars? Asking for a friend
Tropical Buzz
