| S |
1 |
5 |
| 7 |
8 |
12 |
| 14 |
15 |
19 |
| 21 |
22 |
26 |
| 28 |
29 |
30 |
8Likes
01-03-2023, 02:50 PM
al
Cobra Make, Engine: Unique FIA
My toggle has a very small light in the tip that illuminates when turned on.
01-04-2023, 07:22 AM
ct
Cobra Make, Engine: ERA, 428, 4 speed Toploader, Jag rear, Red with White stripes
That sounds a lot easier, can you post a link for the one you have?
ERA#698 428, 4 speed Toploader, 3:31 Jag rear
01-04-2023, 07:29 AM
But it might not be.... For that toggle light to come on it must have both 12v+ and a ground connection there at the switch. The ERA dash toggle switch for the fans is passing a ground connection only to the fan relay. There is no positive feed there at that switch. Changing it out to a "lit" toggle may be more complicated than you think, especially if that "lit" switch is designed to control the positive feed and the little light is an LED.
01-04-2023, 11:33 AM
Cobra Make, Engine: SPF#0760
Adding a positive feed for illumination in a switch controlling a negative pass-thru circuit is a recipe for a smoking disaster! The bulb shares the path to ground back thru everything that is grounded…. Smoke and flames!
Blas
SPFWiringDiagrams@Comcast.net
01-05-2023, 10:25 AM
ct
Wow, makes sense. I am actually following you on this...LOL.
I did order the light you posted the link for. It came a few days ago, nice quality. I have a million jobs to do before I tackle that. The only challenge will be wiring it up correctly to accomplish what you first intended it to do
01-06-2023, 04:18 PM
al
She's been working since 1991?
| Thread Tools |
| Display Modes |
Linear Mode
