November 2025
9 10 11 12 13 14 15
16 17 18 19 20 21 22
23 24 25 26 27 28 29
Old 03-18-2023, 04:09 PM
Default Buddy Bar valve cover
Found and bought for a song a set of Buddybar valve covers.
They cleaned up pretty well with vapor blasting and happy with the look ( That air filter will find another home..).
However, someone has removed the steel tube in the oil fill side and the internal baffles from both. Thinking about filling the oil fill
hole -1 3/8" - with a Granatelli Motor Sports Valve Cover Baffle, part # 451000, this has an id of 1" so can get a breather to fit that.
That would cover the oil fill side but what do I use on the PCV side to stop oil from being sucked into the PCV valve? Id of PCV side is 1".
Old 03-18-2023, 06:38 PM
Blas's Avatar
Cobra Make, Engine: SPF#0760
I see 2 sets on eBay. Both appear to have the internal baffles removed. Probably had rockers interfering so off they came. Probably had the longer necks added to the breathers caps.
Blas
SPFWiringDiagrams@Comcast.net
Old 03-18-2023, 08:50 PM
LMH's Avatar
LMH LMH is offline
In original configuration, the PCV valve goes on the left side of the engine and the oil fill/breather on the right.
Alba gu brąth
