Old 02-19-2002, 04:59 PM
Todd Hedges's Avatar
Cobra Make, Engine: ERA 427SC w/428 & Richmond 5-speed Car 611.
Default Grease
I was adding grease to the ball joints on car 611 for the first time, when at the passengers side upper A-arm ball joint, the grease leaked out, around the mounting flange and never filled the rubber boot.
I tried to tighten the mounting bolts with no luck. Grease still leaks arount the backing plate on top of the A-arm mounting platform.
Any suggestions?
Is the joint bad?
What can I do?
Thanks for any help.
By the way check ou the members gallery for some pics of 611 in process.
Thanks
Todd Hedges
