| S |
1 |
| 3 |
5 |
8 |
| 10 |
12 |
15 |
| 17 |
19 |
22 |
| 24 |
26 |
29 |
30 |
| 31 |
04-18-2003, 03:44 PM
CA
Got my taxes back & went shopping at ERA
I decided to go with the ERA rear assembly with outboard brakes. I also ordered the pindrive accesories. Peter never seems to mind accepting money. Why is that?
Hyde D. Baker
04-18-2003, 03:49 PM
PA
Cobra Make, Engine: ERA FIA #2078. 331 stroker, sportsman block built by Evanuik Performance. 450hp
Nice Choice. We went with that rear end also.
Glenn
04-18-2003, 09:09 PM
ME
Cobra Make, Engine: Original ERA 427sc, Powered by Gessford
Hey TP-
Don't think you're special, Peter likes taking money from me too! My invoice has just run onto its 4th page, and Peter has added each new page with a smile.
Replica is not a dirty word.
04-19-2003, 04:06 AM
nj
Cobra Make, Engine: SPF #623 460/4x2
I dont mean to be stupid, but can someone explain "outboard " brakes? I am not familiar with the term.
Dane
Dane
04-19-2003, 04:31 AM
VA
Cobra Make, Engine: ERA #645, 406 FE
Dane,
ERA uses a Jag independent rear suspension. From the factory, the Jag brakes were placed inboard near the center section (ring and pinion) unit. The brake pads can be hard to get at to replace when worn (ERA actually has a panel in the interior that can be removed). The brakes also tend to heatup excessively under racing conditions due to a lack of air flow. As an option, ERA offers a custom Jag rear assembly that moves the brakes outboard to the wheels (like other rearend setups). Easier to get at and run cooler in the wind stream.
04-19-2003, 04:47 AM
TP, SSSnake & Chaplin,
Glad to see you guys are getting things sorted out for the nice weather. Any idea on delivery dates? I too have been sorting out the car, new valvue cover caskets, oil leak on AF fiting from the oil filter conector to oil cooler, all learning experiences. I sort of miss the idea of a build, but then I can work for a day or two and then go dirve.
SSSnake are you going to have the car complete for Carlisle in May? or to the revolution in June? If so look foward to meeting you after our talk in Pittsburgh.
Corky
04-19-2003, 06:40 AM
PA
Corky,
Goal is to have the car painted for the DVSF III in June. In a couple days the car comes back apart to start paint prep.
Glenn
04-19-2003, 07:35 AM
CA
Last week Peter said that my frame was in the jig. When finished it would go to the powdercoater (approx. working 6 days) then back to get body assembled & bonded. My kit is pretty bare at this point with just the rear & pin drive hardware added. I don't know how long it takes them to do this kind of work. I would guess no longer than a month to a month.5. & then the real work starts. At that point it is really more or less dependent on $$$. I'm thinking a year from now I will be close to driving....I hope!!?
Hyde D. Baker
04-19-2003, 09:00 PM
Hyde,how long have you been waiting for your car ?
04-19-2003, 10:55 PM
CA
I put my depsit in about 3+/- months ago. I was amazed that they could get started on it so quickly knowing the reputation they have for being so back logged. Now I'm just trying to scrape up as much $$$ as I can in order to include as many parts as possible on the initial shipment.
Hyde D. Baker
04-22-2003, 09:49 AM
NY
Cobra Make, Engine: ERA140, ERA 267, ERA GT2038, ERA FIA 2045, ERAGT2077 ERA2893000EXP
Folks:
Here is the link to the ERA website that shows the "inboard" brake rear: http://www.erareplicas.com/427/rsusp.htm
And here is the link to the "outboard" brake rear: http://www.erareplicas.com/427/frsusp.htm
The outboard brakes only cost a few "pintos" more. (Peter will explain the pinto concept).
Jim Holden
PS: The brakes on ACs were inboard, but in racing tend to get covered in oil and difficult to change pads, etc. in the heat of an event, even though there is less "unsprung" weight.
04-22-2003, 10:20 AM
ME
Bob-
Can you get the ERA rear with a 5 lug wheel or do you have to use the 6 pin?
Thanks,
Mike
04-22-2003, 12:06 PM
CA
Originally posted by Chaplin
Bob-
Thanks,
Mike
Chaplin, It's only money! Besides, you'll feel so much better if you go the pin drive route!  I did! Of course it's just that much longer I'll have to wait to finish the car
Hyde D. Baker
04-22-2003, 12:16 PM
ME
FYI-
I spoke to Bob and you can get the ERA rear with the 5- lug. I did get 5 lugs, but I got the pin drive Trigo's with the adapters. Best of both worlds. When I want to go really fast, I can put on bolt on wheels
04-22-2003, 02:09 PM
CA
Sounds like a good deal!  Pin Drives look awsome!
Hyde D. Baker
| Thread Tools |
| Display Modes |
Linear Mode
