Old 12-04-2003, 04:40 AM
REDSC400's Avatar
Cobra Make, Engine: ERA #375 427 S/C - 428FE - Toploader - 1968 AMX 390 Go Pack 4 Speed - My Daily Driver is a 2004 Crossfire
Send a message via AIM to REDSC400
Default U-Joint Grease - What Nozzle or Adaptor??
Good Question for you Old Timer ERA Guys....
While crawling around under #375, while the Cobra was on Jack Stands, I did notice grease nipples on each end of my Jaguar drive shaft Universal Joints. I whipped out the trusty grease gun but the nozzle at the tip of my grease gun just would not fit onto the fitting as there was not enough clearance.
So what is the trick to get these fittings greased?
Do you use some sort of needle adaptor or what?
Thanks in Advance.
Art in CT
See My Website at http://www.lithicsnet.com
A car can massage organs which no masseur can reach. It is the one remedy for the disorders of the great sympathetic nervous system. Jean Cocteau 1889-1963, French Author, Filmmaker
Old 12-04-2003, 06:51 AM
Chaplin's Avatar
Cobra Make, Engine: Original ERA 427sc, Powered by Gessford
I just greased all the fittings on my car last week. I used one of the flexible hose attachments on the grease gun and had no problem at all.
Replica is not a dirty word.
Old 12-04-2003, 07:18 AM
REDSC400 I used the same thing as Chaplin and got all the fittings. You have the car on jack stands, where are the stands, on the chassic or on the drive line and suspension parts? Rick Lake CHAPLIN Mike get back to work tooo!!!
Old 12-04-2003, 07:28 AM
Chaplin's Avatar
Hey Rick-
That was meant for Rick Dorman, but I guess it applies to you too.
Old 12-04-2003, 09:28 AM
rdorman's Avatar
Renegade Nuns on Wheels
How about you both get back to work
Flex hose has always worked for me on the grease fittings.
Rick
OhioCobraClub.com
LondonCobraShow.com
Old 12-04-2003, 12:06 PM
REDSC400's Avatar
Yup, the flexi hose did the trick. Yes, have it on jack stands on the frame. Just moving the wheels allowed me to align the nipples for easy access.
Thanks
BTW:
Also, on the rear drive hub carrier which is the stationary part that is connected to the lower A arm. There appears to be a "plug" on the top of this. Is this an access port for grease packing the rear bearings?
Art in CT
Old 12-04-2003, 12:39 PM
rdorman's Avatar
I am assuming a jag rear here.......
Take the plug out and fill her up with grease.
Rick
OhioCobraClub.com
LondonCobraShow.com
Old 12-04-2003, 04:06 PM
REDSC400's Avatar
Rick:
How do you take that plug out? Mine is a smooth rounded plug with a tiny hole in the middle of it. There appear to be threads near the edge?
Footnote: Some time later, I referred to a Jaguar website and found that the plug is pressed in and it can by pryed out with a flat bladed screwdriver. Did that and filled the reservoir with grease. Nice.
Art in CT
Old 12-08-2003, 07:27 AM
REDSC400 I am not sure what plug you are talking about? I think there is a vent hole in the housing to keep the grease from pushing out of the housing. I will go home and look at it tonight and let you know. Chaplin Mike I am working on MY BREAK. Roderman Rick, Mikes just looking for some attention. I am going back to work. BYE-BYE
Old 12-08-2003, 07:51 AM
rdorman's Avatar
Thats the plug, just pry it out and fill 'er up. Oh and don't forget to put the plug back in!
Rick
OhioCobraClub.com
LondonCobraShow.com
