Old 05-02-2004, 03:53 PM
Default Blown fuses and a jumper box
Wanted to test out my wiring job so I hooked a battery box up to the battery cables just to see what would happen.Head lights work,signals work,horn,fan all seemed fine.Instrument light rheostat fuse blew right away.Wiper motor was running but would not shut off then that fuse blew also.I also hae no parking lights.Wiring seems to be plugged in the right spot but I guess not.Any ideas?
Old 05-02-2004, 04:25 PM
clayfoushee's Avatar
Cobra Make, Engine: Unique, 427SO, it runs
Where was the voltage regulator?
Clay
Old 05-02-2004, 04:55 PM
Over next to the brake reservoir where its mounted
Old 05-02-2004, 06:04 PM
Cobra Make, Engine: Midstates, Genesis 427 S/O
Are you running the circuits that blew a fuse through relays? Have you checked your supply voltage? The instrument lights sounds like a direct short, if it blew instantly. The wiper motor could be a bad ground or lack of a relay. The parking lights could be ground related as well. Do some continuity test to confirm a grounded cicuit. If you need help running test, email me.
Chris
"God saved you by His grace when you believed. And you can't take credit for this; it is a gift from God".
Ephesians 2:8
Old 05-03-2004, 04:59 AM
Wanted to test out my wiring job so I hooked a battery box up to the battery cables just to see what would happen.Head lights work,signals work,horn,fan all seemed fine.Instrument light rheostat fuse blew right away. I also hae no parking lights.>>
The instrument lights and parking lights are on the same fuse. Disconnect the wires at the instrument light rheostat and see whether the fuse still blows. If so, check all the connections at the parking lights. If not, check that none of the R/W wires is grounding out. A less likely problem is a bad instrument light. (I've never seen one.)
<<Wiper motor was running but would not shut off then that fuse blew also.>>
I need to know your chassis number for this (or if your wiper plug comes directly from the front harness or is a separate piece.)
Old 05-03-2004, 05:59 AM
Chassis number is 656.
Thanks for the help
Joe
Old 05-03-2004, 04:29 PM
Cobra Make, Engine: ERA #664 finally done!
check what color wires are in the plug for the wiper against the wiring manual, there were 2 wires crossed in my plug also 2 in the regulator plug also. maybe it happened on yours also.
