Old 07-14-2004, 07:57 AM
REDSC400's Avatar
Cobra Make, Engine: ERA #375 427 S/C - 428FE - Toploader - 1968 AMX 390 Go Pack 4 Speed - My Daily Driver is a 2004 Crossfire
Send a message via AIM to REDSC400
Default Adding Pusher Fans - Circuit Help ?
Hi Guys:
I have a set of twin pusher fans that came with ERA #375. These are the type that mount in front of the radiator. At present, my ERA has the splitter wing in the nose and a single large puller fan behind the radiator.
I am aware that the wiring harness accomodates both the puller and pusher fans.
However, I would like to set up the new pusher fans on their own independent circuit with their own flip switch. I really do not want 3 fans running for about 6 minutes when I pull into the garage after a run. Am I being too cautious about having 3 fans running?
Bob, what is the best way to wire these fans independent of the puller fan?
I just want to turn the pushers on or off with a switch, with no thermal switching activation (via the water temp switch on the puller fan circuit).
What is the best way to protect the proposed new circuit with a fuse? Can I use an existing fuse?
Should I use a fan relay? What are the pros and cons of not using a relay?
Sorry for all the quesitons, thanks so much.
Art in CT
See My Website at http://www.lithicsnet.com
A car can massage organs which no masseur can reach. It is the one remedy for the disorders of the great sympathetic nervous system. Jean Cocteau 1889-1963, French Author, Filmmaker
