Old 08-18-2004, 09:22 PM
joea's Avatar
Cobra Make, Engine: ERA #676, 428SCJ (2x4), TKOII
Default clutch bleeding
My build manual says to bleed the clutch with the car level or the front higher than the rear. This thread says the opposite (rear higher):
clutch adjustment
Which way is correct?
"There are 10 types of people out there....the ones that understand binary and the zeros that don't."
Old 08-19-2004, 03:51 AM
The manual. We have mounted the master so it tilts up a bit at the back so it won't trap air. The slave is horizontal and has the bleeder at the front - and that's the end you want higher. The best technique is to initially bleed with the car lever. If there's any remaining air, raise the front and bleed some more.
