Old 02-01-2008, 12:19 PM
Jim Holden's Avatar
Cobra Make, Engine: ERA140, ERA 267, ERA GT2038, ERA FIA 2045, ERAGT2077 ERA2893000EXP
Doug will advise, I'm sure, but it sounds like a very small adjustment in the hydraulic throw out bearing distance should cure the problem. On mine, it's a matter of turning the bearing slightly on a threaded sleeve. (A wire tie is used to try and prevent the bearing from turning on the sleeve). Problem is you have to pull the trans to get at it. (Doug may know of some trick to adjust it through the bell housing throw out arm hole...)
Jim
Display Modes
