Old 04-14-2008, 06:42 PM
jdean's Avatar
Default Motor mounts question
On the drivers side, where the headers exit the body, there is evidence that the top of the header has been touching/rubbing the fiberglass edge above it.
Obviously, under acceleration the engine is torqueing over and lifting the header against the body.
Any suggestions to stop this? Looks like the motor mount is normal rubber biscuit material and does not appear to be broken.
6th generation Texan....
Old 04-14-2008, 06:57 PM
PARKERPOWER's Avatar
Cobra Make, Engine: HM1035 with 521ci, 612fwhp
Send a message via AIM to PARKERPOWER
John what I have seen done is a piece of chain attached to the block and then to the frame to keep the mount from traveling too far when it revs, but the chain is slack when normal running.
Old 04-14-2008, 07:05 PM
jdean's Avatar
That would sure do the trick. I know I have seen that on drag cars too.
Old 04-14-2008, 08:25 PM
Kramer's Avatar
Cobra Make, Engine: ERA 739
My car is not operational yet, but I have heard of the torque causing this issue. (I have had other issues during the build with the pipes hitting the body as well)
There are two things I would consider before a chain.
1) Change out your motor mount with one of the ERA versions with the extra bolt in it. Call ERA, they will get this to you.
2) While my car is just about finished, I took another step and fabricated some thick metal squares to put inside the motor mount perches. These metal squares are a pefert fit to the inside of the perch and should keep things from moving around too much.
Kramer
Old 04-14-2008, 08:28 PM
jdean's Avatar
So Kramer, are you saying you will use solid metal for motor mounts?
Thanks for the info on the other mount from ERA, I will call them.
Old 04-14-2008, 09:13 PM
Kramer's Avatar
No...I use the motor mounts ERA sent me. They had the extra bolt in as shown here:
http://www.erareplicas.com/427man/en...tmod/index.htm
When I dropped the motor in, the motor mount bolts slide into the perches on either side. Once the engine was in the car and level, I fabricated a square metal piece (with a hole for the motor mount bolt) and place in on the inside of the perch itself to keep things from moving around a bit. I think it will work, but again, my car is not on the road yet.
Make sense?
Old 04-15-2008, 05:01 AM
hi-tech cobra's Avatar
Cobra Make, Engine: Hi-Tech
Kramer,
Those don't look like FE motor mounts in the ERA link, what are they?
Old 04-15-2008, 05:48 AM
John what you might do first is buy a new stock mount first and try it as the old mount may have had oil or something on it that caused it to soften up. if you still have the same problem then you could always add the chain or drill that new mount and put the bolt through it like era did.
Old 04-15-2008, 06:32 AM
Clois Harlan's Avatar
John,
Just drill a 3/8" hole thru the rubber and metal part of your motor mount on the drivers side. Then insert a nice 3/8" bolt - grade 5 and use a 1" washer on both sides with a locking washer followed by the nut and you will solve the problem for under $5.
Clois
"Let's roll"
"Be part of Something Good
Old 04-15-2008, 07:31 AM
Jim Holden's Avatar
Cobra Make, Engine: ERA140, ERA 267, ERA GT2038, ERA FIA 2045, ERAGT2077 ERA2893000EXP
You might want to do a search on this topic. There was an extensive discussion concerning motor mounts several months ago.
As an aside, I have used ERA's "bolt through" motor mounts on both my ERA427SCs and my ERAFIA (this due to the Weber air horns hitting the hood when the motor torqued over.
Old 04-15-2008, 10:12 AM
STCinc's Avatar
Cobra Make, Engine: Superformance #1676
I'm running solid mounts from Rodney.. They are awsome!!! Get Rodney by email at 'rodscobra@shaw.ca'
Also see this thread:
http://clubcobra.com/forums/showthread.php?t=76218
I'm running a 427 Stroker and love the mounts!!
Sean
Amendment II
A well regulated Militia, being necessary to the security of a free State, the right of the people to keep and bear Arms, shall not be infringed.
http://www.archives.gov/exhibits/cha...ranscript.html
Old 04-15-2008, 05:51 PM
SSSammy's Avatar
Default John, come look!
Sorry I didn't see this earlier. I have done the bolt mod myself on both sides. You don't need to get them from ERA if you have good mounts. And I'll show you the shims and tell you how I installed them.
Here's Kramer's thread on this issue. See the last page for my solution:
ERA folks...please help / getting frustrated
You're one us now and you have local ERA experience to benefit from You HAVE downloaded the manual haven't you?
Sam
Last edited by SSSammy; 04-15-2008 at 06:13 PM.. Reason: added link to earlier thread
Old 04-15-2008, 06:17 PM
Originally Posted by hi-tech cobra View Post
Kramer,
'63-64 Ford 390-427.
Old 04-16-2008, 01:19 PM
jdean's Avatar
Well, I lifted the car and checked it out from underneath. Turns out when I push the drivers side headers up, moving the engine a bit, I could see where the existing mount rubber is starting to seperate at the top.
With the car just sitting there, you cannot detect the cracking since the rubber is compressed vs. trying to open up.
This is the culprit, so I ordered a new mount from ERA with the bolt-thru mod.
Thanks to all the ERA fans/owners who chimed in to help the latest ERA-head.
BTW.....can the mounts be changed out by raising the engine a bit and without removing the headers?
Old 04-16-2008, 01:36 PM
Chaplin's Avatar
Yes. Just remember to loosen your trans mount bolts a little bit too.
Replica is not a dirty word.
Old 04-16-2008, 02:26 PM
Cobra Make, Engine: ERA 427 SC with 428 PI
I solved this problem by putting 1/4 washer between the motor mount and the frame on the right hand side.
"Is it original ?" -- " Yes! But some parts are new."
It's just easier this way.
Old 04-16-2008, 05:30 PM
jdean's Avatar
Sammy,
I got a manual with the car....have not read it yet....too thick!!
