| S |
1 |
5 |
| 7 |
8 |
12 |
| 14 |
15 |
19 |
| 21 |
22 |
26 |
| 28 |
29 |
30 |
06-18-2008, 10:16 PM
Cobra Make, Engine: ERA, FE BBF
I agree with Bob - you should definetly talk with Ron Randall about painting your car. He does really nice work and he is a great guy to work with.
- Fred
06-19-2008, 03:44 AM
NC
Cobra Make, Engine: ERA #775
Thanks for all the suggestions.
patrickt - another tough decision to make!
zoera-sc7xx - there were several cars there that were painted by Tony, and they really did look good. Peter thought that for what I wanted, he would be a good choice, so I am leaning towards him.
xracerbob & Fred - is he the guy that also does the metalizing? I did plan to speak to him.
One of the things I did while at ERA was to look at the paint finish on each of the cars. All were great. Peter was also nice enough to let me know who the painter was for each. After looking at them, I would think that unless one is looking for a special scheme that maybe one painter excels at, one really isn't making a mistake with any of them.
Ray
06-19-2008, 03:54 PM
Ray
Yes, Ron does the metalizing. The attached is an example of his work:
06-19-2008, 06:09 PM
CT
That's pretty wild, especially on the new car with all the aluminum panels.
06-20-2008, 04:40 AM
NC
Fred,
I assume that he gets the hood after it's painted? Then he returns it to ERA? Did you do this thru ERA, or thru him? Looks pretty good to me.
Ray
06-20-2008, 06:47 AM
NY
Cobra Make, Engine: ERA 758 KC Pond 482
Ray-
Ron painted my car so I had it done while it was there. He can do it afterwards as well if you have one of the lesser painters do your car
06-22-2008, 09:17 AM
OR
Cobra Make, Engine: ERA #684, 428 FE, TKO600
Ray:
Rolling the edges refers to smoothing the edges of the body where the cured material was cut with a saw or knife to remove casting flash. It makes for a much more "finished" look.
DonC
06-22-2008, 12:14 PM
Originally Posted by DonC
Ray:
DonC
Yep, and there are other little things that you don't think about but that your painter will, such as finishing the inner back side of the trunk lid, the splash area around the gas cap, red & black colors cost more, silverish colors costs a lot more (mine was not a silver color, but it was close enough so that it cost more  ), tricolors you need to ask. If you like the hood scoop to appear to be part of the hood (instead of rivets) that'll cost, rondels cost, how they're done around the door split costs more, the inner engine tunnel will cost you, and so on, and so on.... And these are things that I can remember, I'm sure there are a few others that I have forgotten.
06-23-2008, 08:53 AM
NC
Definitely sounds like I need to talk further to the painter!
pstrickt, if you don't mind sharing, what did you have done? I'm hoping not to miss anything.
Ray
06-23-2008, 11:20 AM
patrickt, if you don't mind sharing, what did you have done? I'm hoping not to miss anything.
Walt & Diane at CCC had a team of elves prepare all the body seams, block the body, align the doors, hood & trunk, round the lips under the dash and behind the seats. Round the inner wheel well lips as well. Spray epoxy gel coating and block to a flat finish, then spray epoxy primer and block to a flat finish, then spray base & clear coat with dual stripe to a show finish. Bake at 140 three different times during priming and painting. Extra dough because of the color. Extra time delay because some of the elves collapsed from heat stroke mid-way through this process (that summer was particularly hot). The result was absolutely gorgeous.
06-23-2008, 11:38 AM
NC
From the pictures I would have to agree on the result.
When you spoke to them about painting your car, is this what they recommended to you to have done, or did you tell them what you wanted them to do? Reason I'm asking this is because I'm wondering how much detail I should get into with them. Like everyone else, I want a great looking car and don't want it to look like something could have been done better or that they missed a spot so to speak.
Ray
06-23-2008, 02:49 PM
Ray
Ray,
Ron Randall did a bunch of work on my ERA prior to painting. First, he totally rebuilt the edges of the fender flares on my body to get a more athentic look.
Also, it is very difficult to get a smooth finish on a fiberglass body. To do this, Ron sprayed the body with multiple additional gell coats and guide coats and then hand blocked the car to remove all imperfections and get a smooth finish that will not allow the underlying fiberglass to "bleed through". Here's a picture after a gell coat and guide coat has been applied in preparation for blocking.
This step takes alot of work and is one of the major differences between an average and a high quality paint job. This sort of prep work followed by multiple coats of clear with proper color sanding and buffing create a perfectly smooth, high gloss final paint job as shown in the following pictures. I doubt that you will ever see a smoother, more perfect finish on a fiberglass body.
As mentioned in other posts in this thread, its also important to properly finish the edges of the cockpit around the dash, etc. to get an authentic look. You can see the results of Ron's work here in the following picture.
Note how perfectly blended the rolled areas by the dash and the door edges are executed.
Give Ron a call as he can explain these ideas much better than I can.
- Fred
06-23-2008, 03:00 PM
NC
Ray,
- Fred
Fred, I was and am quite impressed with the paint on your car. I do plan to speak to Ron about the possibility of painting my car.
Ray
06-24-2008, 06:54 AM
fl
Tony painted my FIA and both he and Peter recommended the spray on Clear Coat on the rear fenders to protect against rock dings. I went with it. It cost all of $100, is a clear (has a slightly opaque tint to it) finish, is barely detectable, and works. So far with 1500 miles, not a ding - and the fender has been hit by small road debris. Rick
06-24-2008, 10:13 AM
NC
Thanks Rick, I'm adding that to my list of questions for the painter!
Ray
06-24-2008, 12:24 PM
Here's a picture of the rear fender protection. You have to look hard to see the line that tells you where it starts. It's a little easier to see in real life, but this will give you an idea.
06-25-2008, 05:00 AM
NC
Is that the clear film from 3M?
Ray
06-25-2008, 06:29 AM
Ray
Yes, it was applied by the folks at ERA, not CCC. But I believe you can have it done either way. I'm told it takes some skill, though -- it's not like putting a sticker on the windshield.
06-24-2008, 09:40 AM
MO
Ray,
Congratulations on the selection of ERA. I ordered mine last September and I will get it this September. I have #768. The photos you took were great. My son and I are going back up to visit the facility just before they ship our car. We just came back from the London, Ohio show. Only one ERA out of about 250 cars.
Clyde
06-24-2008, 09:55 AM
NC
Originally Posted by M164285
Ray,
Clyde
You must be excited, and counting the days by now? How far along is your car?
Ray
| Thread Tools |
| Display Modes |
Hybrid Mode
