Old 02-14-2009, 03:54 PM
428street's Avatar
Cobra Make, Engine: BRG ERA street car w/428 PI, Sunburst wheels, undercar exhaust, original interior, no philips head screws!
Thanks guys for all the compliments...Just came back from a 30 mile drive...took the kids one for a short drive each then I took in on the highway. This car is like "budda"...it just rides very smooth. Couple of things I ran into....I think I initially flooded the carb as it would not start...tried to take a ride 2-3 hours ago, then just gave up. Not used to a carberator vehicle..left it alone for a couple of hrs. and it started no problem...probably was pumping the gas pedal which I see now is a no, no...Another strange thing, after I came back from my ride I shut the car off just to see if it would start easily (again, I getting to know it and get confidence), well, it did start but it was a slow wind, then it poped...tried it again, same thing...almost seems like when it get hot it bogs down some electrically...I hope it's not the starter as it was a ***** to put on...
Old 02-14-2009, 04:27 PM
Default How I start mine...
If the engine has not been running, I give it two pumps and then crank the key. It will fire right up and then I just lightly feather the pedal until it warms enough to idle smoothly. If the engine has been running, never, never, never pump the pedal before cranking. Instead, just crank the key and lightly feather the pedal once it fires. If you flood your engine, leave it alone for a while -- the worst thing you can do is keep punching the throttle. In fact, we had a member of our local Cobra club have his engine catch on fire because he flooded a hot engine, kept pushing the throttle, and squirted gas on to a hot manifold. You do have a fire extinguisher on board, right?
Old 02-14-2009, 04:44 PM
428street's Avatar
Patrick: I got the starting thing down...any idea on why it starts very slowly after I have been running it. I am not touching the gas at all with this problem...the best way i can describe it is if I had an uncharged battery and the starter was barely turning the flywheel around...then it pops and starts right up...almost like it is getting stuck..
Old 02-14-2009, 04:50 PM
Your engine is new and possibly a little tight. Give it some time to break in. If you're still having the same problem after a couple of hundred miles then it could be the connections to the starter motor, the starter motor itself, or just a timing adjustment. New engines need to break in a bit even if they were broken in on the dyno.
Old 02-14-2009, 04:55 PM
428street's Avatar
oh, also...I had a fire extingusher when I tok the car home, took it from my house and I am getting a new on on Sunday..starting to built my tool kit as well...I saved the thread of 4-5 months ago on all the tools....I'm not going to get crazy, just the basic stuff...Any recommendations on the F/E?
I will probably get a chrome one since the standard red ones will stick out like a sore thumb in the car..
Old 02-14-2009, 05:01 PM
428street's Avatar
I'm not super worried about it I'm just feeling everything out, listening and taking notes...problem is I'm not sure what it normal...for example...I have "some" tapping coming from the heads...best way I can describe it...I'm sure the rocker arms need adjusting...I'm going to call the guy that helped with/build my engine on Monday to get his input...probably have about 100 miles between the car ride home yesterday, Dougs test ride and my 30 miler a while ago..
Old 02-14-2009, 05:04 PM
I understand -- it's kind of like when you bring your first baby home from the hospital. It gets easier. On your fire extinguisher, I have a chrome Halotron unit mounted right behind the shifter. It makes a perfect elbow rest and it won't leave that nasty white powder residue. Do you have a solid lifter cam in your engine?
Old 02-14-2009, 05:24 PM
Congrats! That car is sweet!
Maybe the timing is a little high for hot resarts?
My theory is just to beat it harder. Don't be over worried about hurting anything. These cars a tough. Enjoy the bee-jesus out of it.
The driving pleasure is where it is at. That is what they are about anyway.
The guys sitting in the lawn chairs at car shows, dusting off their cars every five minutes are missing the true meaning of having one of these cars. my opinion anyway
ENJOY IT!
Old 02-14-2009, 05:35 PM
about the engine noises............the valves are right in front of the dash and valve covers kind of amplify engine noise directly toward you. No worries. If something is really wrong the sounds get Way louder. Just trying to give some piece of mind
JB
Old 02-14-2009, 05:54 PM
428street's Avatar
Thanks JBCobra, trust me this will not be a garage queen...I'm driving this beotch! Will I bring it to a show or two...maybe but I'm not looking to take any trophies...
Old 02-14-2009, 05:57 PM
You are the man!
Meet us up in Watkins Glen for the Vintage Grand Prix. We go nuts up there. You will be in your glory.
Old 02-14-2009, 06:02 PM
428street's Avatar
I'm going to try to make it to a bunch of stuff...Lime Rock is in my neck of the woods...not sure how much track stuff I can do as I do not have a roll bar...I'd love to open it up somewhere!
Old 02-14-2009, 07:15 PM
After you've broken the car in by driving gently for a few hundred miles, take your car to a large open space where you can safely lose control. The parking lot of a ball stadium or large concert arena early on a Sunday morning is good (lots with NO light poles, please). Drive in a circle, lift off the throttle, and learn how your rear comes out unexpectedly. Try accelerating "too hard" out of a pretend curve and see what happens. Experiment with hard launches out of the hole with your wheels not completely straight so you start fish-tailing. With no roll bar you might have trouble getting on some tracks for hi-po training. An instructor might be a little hesitant to sit in that passenger seat but you can at least follow him and learn the proper lines (if they let you on the track, that is).
Old 02-15-2009, 03:20 AM
SLHetal's Avatar
Patrickt is right on with good advice. I did the same thing with my old 1958 Carrera Speedster after a total restoration. It was basically a new car again and I had to learn it all over again. A few weeks later I nearly became entangled in a traffic disaster but was able to avoid mishap by using the little car's power and agility. Knowledge is king.
Sam
Old 02-15-2009, 07:11 AM
Default The Two Most Common Mistakes...
Originally Posted by SLHetal View Post
Patrickt is right on with good advice. I did the same thing with my old 1958 Carrera Speedster ... I had to learn it all over again.
I think the two most common mistakes with a new Cobra that I have seen over the years are: 1) Learning about lift-throttle oversteer the hard way; and 2) Showing off with a cool burn-out and then losing control of the car. I guess there is that occasional newbie that is heard to say "I was in a perfect four wheel drift at 110 and just lightly kissed that guard rail...." I can't say I recall hearing that, though.
Old 02-15-2009, 07:47 PM
Cobra Make, Engine: ERA 289 FIA #2027, 65' 289" PS wheels
Default another way to audition for the old "Joey Chiltons? Auto Thrill Show"
428 and Patrick,
OK, to quote Pat- ""I think the two most common mistakes with a new Cobra that I have seen over the years are: 1) Learning about lift-throttle oversteer the hard way; and 2) Showing off with a cool burn-out and then losing control of the car.""
Good advice, I would add ONE that almost got me.
I think the short wheel base makes the car more unstable on up/down undulations in the road. A "dip" or "hump" that I was barely aware of driving my 67' Corvette was an opportunity to go "fly" in the much shorter wheelbase Cobra. Add a passenger for ballast and it was "off to the THRILLS SHOW"!
OK, full throttle acceleration over the otherwise "unremarkable dip" resulted in the Cobra rear end in a full "squat" and front end "pitching" up...enough to toss us back/forth a little...I inadvertently got off/on again on the accelerator...passenger thought it was great fun...I realized I had almost lost the car as traction broke and the car fish-tailed a bit.
My friend with a race-ready 63' 289" smiled at the story..."they sorta ride like a "buck board" don't ya' think"?
Have fun, take your time, r&r all the bolts and especially the knock-offs...I had NO idea how firmly they had to be whacked with the lead hammer...NOT tapped...WHACKED. I almost lost one.
And, always, be sure to "check your 6" before you get on it...
Oh, 428 your car is beautiful, like the attention to stock details, no hood scoop...and the color is a favorite of mine...(after maroon).
Since you went to all "straight slot" screws...YOU don't need to carry a "phillips head" screw driver in your tool kit...just spare change...dimes work great on the SPAX shocks.
Pete
ERA 289 #2027
Old 02-15-2009, 09:47 AM
Great Asp's Avatar
Cobra Make, Engine: SPO 2715
This is some of the best advice you will ever get regarding your Cobra (More important than BBF or SBF )
E
Old 02-15-2009, 11:06 AM
428Street, once you start learning how your Cobra can surprise you sights like this will start making sense to you. And when your wife says something like "I wonder how he managed to do that?" you'll be able to say "Let me tell you about lift throttle oversteer...."
Old 02-14-2009, 06:06 PM
http://www.youtube.com/watch?v=EpdO8Dy7_iQ
I am not sure if I did this link right but if it works you can see a bunch of us at the begining of the video
Old 02-15-2009, 01:28 PM
428street's Avatar
oh boy, thats a bad day...I have to confess, I am the farthest thing from a speed demon...I was one of those kids that the parents of my friends were happy to find out I was driving when we went out because I didn't speed and was fairly responsible (I had to be but that is another story in and of itself). I am going to test this thing out though.
Just came back from another 30 miler...the heater is nice and really kicks off some good heat.
This car has exceeded my expectation...Every time I drive it I am more and more satisfied. I have a Boxster S which I love and drives like a dream...I was a bit nervous when I started building this car that it would not compare to the Boxster but I have to tell you it is close...the car is EXTREMELY responsive...almost like if my foot goes near the gas pedal she wants to go and go quickly...on the highway the car just glides...
